dt 125 keeps blowing spark plugs?????
nope i tryd it and it didnt work anything ele m8?? runs for about an hour then blows the spark plug? thanks for the help cheers. tom
thanks for the help ill will have ago l8er afta work thanks .tom
cheers m8 ill have a look afta work thanks. tom
my yamaha dt 125 03 reg, will run for about an hour and then blows the spark plug causing it to miss fire can any1 help me plz:D thanks. tom
should there be petrol there??
sorry took ages too write back had internet problems, i chekd by carb took it apart looks ok could there be anything ele thank you very much. tom
There is a lot there, i did my barrel gasket and i took eampyd the petrol from there and i started it up tickd over for abouts 5 mins then cut out and didnt start again ( alot of smoke as well ) thanks for your help. tom
i sorterd my other problem out on my bike, now i have petrol at the bottom end of my engine were the piston rod is, should it be there:s many thanks if u can help. tom
- hello
hi yamaha dt 125 03 reg water coming from manefold
thanks for replying to me cheers tom. yh i checkd for cracks and it wud be a big 1 for the amount off water coming out, i cleand it really well, and i chekd the bolts and there are tight on. thanks tom.
hi, i did my head and barrel gasket on my dt 125 03 reg because the oil was creamy and was miss fireing, afta i put them on i didnt put my eghaust on and when i was filling the rad water came front the eghaust manefold, there is lots more comparsion and alot of water spuing out when i kick it. thanks if you can help me. tom
wapsy
Joined
Last visited
