Yamahappyuk
  1. outworking in Dubai sry Bhurthorpe is a nice little show & the Lymm one too ! but I`ll miss this also , grrr will be off down the A49 to Glastonbury then across to St Davids early September so at least I`ll get some nice runs in dare I say it ......... on my "new" RC31
  2. cancelled ? why have they cancelled the best show of the year ? if I don`t go anywhere else , I always make sure I attend this one with a new restoration / project if possible . even the parking area bikes were worthy of a few photos , it was the highlight of the year for me . what a joke ... Pete / Wigan
  3. Hi , i stick to the standard gearing and use the GENUINE front sprocket as it has a rubber guide , pattern ones are rubbish . Fit a Scottoiler and the DID 50 zvm ? standard chain . My FJ has now done 80,000 + miles from new and only had one new chain ... Pete *
  4. BB King ...
  5. hi there Chris , i did 30 000 miles+ on my RXS and had a similar issue once , it could possibly be the needle valve is worn out , totally messing up the fuelling ... this cost around £15 from Yammy if i remember correctly , i might even have one somewhere if you`re lucky but it will take some finding / Pete *
  6. i knew there was a Yammy in there somewhere ...
  7. a YB 100 side stand fits RXS 100 as i have done this ...
  8. i agree about fuel , is all chemicals now thats true ya , i`ll look into a larger jet , be careful out there , bye for now ...
  9. timing was the issue i think , someone meddling pfff , was a brand new piston and had run in for 1000 plus miles , main jet is standard 130`s i think it is ( needle is on the centre clip position ) bike was running ok at moderate revs but then on other occasions was terrible , could not keep any decent pace up hills without full throttle even though it was not revving high , was all i could do to keep going ... i changed carbs and all the internals then holed the piston .
  10. ahhh yes , sorry , i have 2 sets and could see one assembly was deformed so i fitted the ok ones which looked flat against the housing
