xj600 diversion non starter
Same happened to mine, corrosion in the block connector stopped the starter solenoid from being energised. It's very exposed to all the rear wheel spray.
- XJ600N troubles
XJ600N troubles
Hi, I also have this issue and wonder if you found a solution for it? Thanks
Horns.
Just about to put twin air horns on my bike, sick of a weedy sound! 112dB here we come, try hearing your mobile phone over them
Road Fund Licence RANT
Not so fast, I was pleasantly surprised to get the car tax for our (new car) Y2000 530D ice cap melting car Get a car that will last for 500,000 miles and won't rust for quite a long time, long enough for the petrol to run out and we're all eating beans for our own gas production
Problem using Firefox with this forum!?
Works for me User error?
DUKE TO YAMMY
- Law On Motorbikes?
Is it still restricted to 11 HP (it's probably kW now)? I can't remember if it was 11HP it was a long time ago.- YZF750R Race Can
Mine also gets through MOTs with no baffle Just need to go to the right place for the MOT- Homebased anti-mist solutions
It says not. It attaches to the cheek pads and a Velcro pad on the chin guard pulls it away from your mouth forming a chamber to stop you suffocating!- Homebased anti-mist solutions
Get yourself a Foggy Breathguard, only £12, bloody fantastic- r1 oil issue
It's a real pain when you see it, you back off and then the bloody thing goes off! I gues the only thing to do is keep at around the max level to stop the oil light thinking it's a cyclist's rear LED Thanks- r1 oil issue
I also have some strangeness with my oil on a 01 R1. The level is between the min and max however I have the oil light come on and then go off 30 sec later. Should the oil always be kept at the max?- 2000 R1 normal operating temperature
I have a 2001 R1, idle in traffic it's 105, normal riding is around 72.- R1 headlights
Hi, not sure about Xenon kit, I went for some Anti-Vibration Piaa Xtreme White Plus bulbs for my R1. They burn twice a bright for same current just a direct replacement for what you have in there, although not cheap @ £40/bulb. You can get cheaper but not sure about the vibration element. - Law On Motorbikes?
diychap
Joined
Last visited
