johnson13
  1. johnson13 replied to lwcrs2001's topic in Naked
    I had an XJ6S (half faired version but mechanically the same bike) for over a year. The XJ6 will handle realistically everything you throw at it, is not supersport but has a fair amount of get go, comfortable for the pillion, comfortable to ride, the underbody exhaust is fairly quiet but the plus is no damage if you drop it or fear from the pillion from burning. Quite a solid bike, suspension can be a little bland when pushing it hard-ish (not a racer here) but for the budget I think you get a lot of bike for the money. Direct competitors the Kawi ER6, different engine, similar power, more vibes than the XJ6. For commuting I think is an excellent bike, fairly narrow, easily flickable through traffic.
  2. johnson13 replied to scfmarshall's topic in Naked
    I've heard the car will pass MOT emissions test withought the underfloor cat. Never done it myself though and I've never passed emissions withought a cat on another car even though people said I would. Check where the DP meets the underfloor cat. It will have either a slip joint or a flange and olive. If flange and olive, get a new olive for about £5 from an exhaust fitter. In my experience, I found that to pull the sections apart you need to get the exhaust rear boxes back wards and there may not be enough slack in the hanger. There is a bracket that can be undone that supports the back box but it's nuts become corroded, also, the dome headed bolt is captive within the bumper support so if it starts to turn with the nut, it's an air saw/grinder job and new nuts + bolts. Support the back boxes, possibly undo the middle support rubber at the end of the underfloor cats (there is room for fore and aft movement but it's easy enough to undo) and undo the 3 (or 2 if olive) circlips and in an ideal world the parts should separate - try some wd40, swearing, hammer, twisting etc to loosen. I'd strongly advise to get an emissions test done after the work. I've been roadside tested before, fortunately with cat installed. The police were there and the VOSA people. I'm not sure what the rules are here, if they look under the cat and find you've removed cat/s deliberately, there may be a hefty fine to pay.
  3. Hi all, just wanted to say hello as i am new to this site. My names Callum from Manchester and im restoring my 1989 yamaha yb100 im new to motorbikes but a car mechanic by trade. i brought my yb100 in chorley in november last year as a project for the summer but now i have a problem its was runing but it just cut out and wont start again iv replaced the spark plug and ignition coil points and condenser but im still not getting a spark i tested the voltage coming from the source coil in the flywheel magneto and im only getting 0.2v. Iv checked the connections and all seems fine but im still gettin the same reading of 0.2v so now im at aloss any help would be great.
