ipbrennan
  1. ipbrennan posted a post in a topic in The Bar
    Just purchased an xs360 and i could get it started but I have to give it gas to keep it going, if I let off the throttle once it's started it dies. I'm hoping this is battery related because when I try to start it back up it won't turnover, when I trickle charge the battery for a while it will always start up first try just won't stay running. help please!
  2. ipbrennan posted a post in a topic in The Bar
    Just bought an yamaha xs360, everything is in great shape but I had a problem with the clutch. I went to pull in the clutch while stopped in my driveway, heard a pop, and looked down at the clutch cable which had popped out of the push rod assembly and casing. on further inspection and removal of the case i found that the spring connected to the worm nut was stretched out and had little to no resistance. I have since replaced it, put the clutch cable back in, case back on, but now i get no resistance on the clutch lever, i can pull it in but it won't engage and there is no resistance. I have little experience with bikes in general but I'm trying to learn anything is helpful. Also a question about the push rod, is it supposed to just stay put or should i feel resistance when i push it in? how does that whole system work?
