nilzor
  1. nilzor replied to nilzor's post in a topic in Classics
    is there a chance that it doesnt work without the original key? I can put another key in and change the position of the ignition. However the key is kinda loose in there...
  2. nilzor replied to nilzor's post in a topic in Classics
    Thanks all, By now the battery completely drained. Would that have an impact on the ignition? @blackhat250 What do you mean with Mag cover, like the flywheel?
  3. nilzor replied to nilzor's post in a topic in Classics
    yes, i also held the end coming from the coil against the engine to see if there's a spark there
  4. nilzor posted a post in a topic in Classics
    Hi, I have a problem with my AT3... I tested the spark plug to see if it gives off a spark. I also took off the connector but no luck here as well. The next thing I guess is to thest the coil. How do I do that? Do I need to yake it off the bike? the Cables seem to be soldere on... Thanks for any advice, Nilzor
