dt502001
Everything posted by dt502001
  1. I dont know about a vaxuhal van but to get my wr in a ford windstar I had to take the front wheel off.
  2. Mankini make it with your ball's and pecker right infront of the snake bite shaging a chick LMAO. Personaly I would skip the snakes and mix a yam tune fork surounding with the pistons theme. The whole paring thing I would hunt the dick down and deal with him,jimmy hoffa style never to be seen again.seriously I would sleep in my what ever and next time they showed up,,,, well i shouldnt say but it would be the last time they ever fecked with anything of someone elses.Thumbs are removable
  3. dt502001 replied to blackhat250's topic in Random
    Ya tourque from a e motor is instant and dosent realy drop off,the new batteries don't blow up unless you over charge them.running them below thier thresh hold is the big problem.Once they big guys figure that out and how to put it in a car/truck nobody will want a oil burning anythin. I have a traxis trck and if I could have the same power in my jeep. I would swap the 4.2 lt motor inaminruning full power for 1/2 hr in scale would get me just about anywhere I would ever need to go normaly.And the mft would doo wheelies,crawl any hill/rock climb better. I would need extra axels straped all over the truck as they would be breaking all the time. Give the big companys time and nothing will beat a e anything. Inthe mean time we get raped at the pump to play
  4. dt502001 replied to blackhat250's topic in Random
    Foams in short time they will build a e car that will dust that,look at porche,ferrari,the new bmw all working on fast cars e driven .The bennifits of a e motor is you get 100% torque from 0 rpm no turbo lag.It will look something like 4 250 hp motors awd and a 1 cylinder diesel motor to charge the batteries.Toyota and bmw are working extensively on battery tec,it just the batteries that are holding them back.The manufactures no people want fast suff and won't settle for boring prius just to be green. In the mean time we can enjoy all the hp we can handle dodge released the new Hellcat 700+ hp,kaw with the new h2,and all the bike companys are shooting for the 200hp mark,right now we are living the power junkies dream wasn't so long ago that if your bike made 100hp and your car made 300 you had the fastes now meh.Fords new 4 cyl turbo make's 300 v8's of yonder couldn't make that stock.During the gas crunch of the 70's the 76 corvet made a whoping 178 hp out of a 305 cid v8 Me I am excited to see what comes next,no oil changes ,no exhaust system to rot away,no injectors/fuel pumps to break,no valves to adjust/break,brakes that last 4x longer Have day out and go to your local rc club and check out how fast the e cars are ,nitro used to be the dogs balls,now the saying is "who needs nirto when we got lipo" 1/24th scale cars hitting 100 mph cheap dependable brushless motors.Build something like that full size and see how many tires you go through a year,your fto wouldn't stand a chance.
  5. dt502001 replied to dt502001's topic in General
    I should have read that all the way Before starting whith the impact cordless drill.... now I have a hole all the way through my thumb .any good way to stop the bleeding.It's getting all over the puter. Joking not quite that bad to need to drill it yet ,Iced it right away for a good hour ,But it's a lovely shade of purple and black,green still can't bend it gona be a fun week trying not to bang it up again. It's in the nocking your balls the wrong way range of quick hurt still. Livable but you just know you dont want to do it often.
  6. But you could probably pick up a used motor anywhere in the USA cheaper than fixing your old one.
  7. dt502001 replied to slice's topic in Yamaha Workshop
    Yep as drewps said normaly that info is in the manual,not always but 1 of the carbs will be stamped in small alfa numerical code just above the float bowl also.
  8. dt502001 replied to Wiffy's topic in The Bar
    Your pictuers suck can't see em
  9. I think I will go find the hammer. running low on mind bleach,and have another shot at nail driving
  10. Nope that was your generation LOL melinumem
  11. dt502001 replied to stroker crazy's topic in Projects
    He has been back since jan 2013, too bad would have liked to see it finished.
  12. Sure old gas caps get pluged on street bikes and don't vent. Next time it does this open the cap see what happens or do all the test's on the fuel system , that is only way you will konw for sure.None of it hard to do and dosent take long,BUT you need all the tools. Look on the tube lots of ways to make you own tools for the fi system,a hose with the right fittings and a pressure gauge in the middle is all a pressure gauge is. Welcome to owning a FI bike,
  13. Yep there is a arrow on the valve and it should point away from the cap. The other thing you can check is fuel flow/volume when it acts up ,you would need to disconnect the fuel line and jump the relay to feed the fuel pump and see if your getting a good flow of fuel about 1 lt in 1 min.Then you would need a fuel pressuer tester to install in line and check the amount of pressure the pump can deliver if you have 15lb injectors then you need 20 lbs of presuer ,but that will be in the manual min and max fuel pressure.
  14. dt502001 replied to dt502001's topic in General
    Lol It's been ? 25 + years since the last time I have done that, I swear it would have looked like a cartoon,thumb goes flat,,,, eyes bulge out of head and hammer goes flying and me jumping around *&^%$#$%^& my head off. This one will be a nail off I am sure it's black past the knuckel and swolen. Simple little job of building some cold boxes for the garden,knock a couple of 2x4's together " how hard can that be " .I will stick to steel and welding. Only good wood is for burning I feckin hate working with wood. It was a realy stupid mistake I handent set the nail in far enough and everything jumped when I hit it and had my thumb in the wrong spot,a job I should have left till the next day when I wasn't tire and it wasn't dark. OH well laugh I can now.Just hope the swelling goes down by monday gona be hard to work with a thumb that wont bend. PS the name of the hamme is"sure strike nail hitter" 30 oz should have culed into to that one,and bought the cheapo one
  15. 1st 62000 with no service anything could be wrong 2 nd Who are you, stop in the new menbers section and say hello,, bit about ,and what knowlage you have if any about how to fix this. 3rd Post you question in the proper section in workshop,add more details about what is wrong other than it sounds wrong,none could answer a quetion like that just far to vauge.
  16. It happens in lots of wireing digrams,you just have to be smarter and look 2x at them,walk away and rethink it.People who only draw them diagram's on thier etcha sketch and don't work on the vehicle themself don't think about what they are drawing. Personaly I like the factory wireing diagram for any job but even then they can be wrong ( 1/2 modle years are the wrost),but that is very rare ,unlike haynes,and they are normaly very good, and the others who I would not trust. The rest of it looks solid,it's only the lighting circut/rectifing and regulating.So just think of it like water the switches are dams ,,open or closed and directing the flow in the right direction,from source to ground. and turn things of and on. Building a wireing harness is not hard all the math is done for you and all you need to do is hook up the parts,LMAO if you have a correct diagram. and the proper plugs.You got this far and have spark so you should be able to get the rest done. Just remember it is time consuming checking everything.2x before hooking it up.
  17. dt502001 replied to blackhat250's topic in Random
    It goes deeper than that,some states tried to make it illeagle to grow your own food on your own property and if you do your on the watch list. as non conformist Read the book the 85 who own the world,Or what ever you find on the net, even that is close,, hard to hide those kind of facts,, we are just pee on's for thier entertainment,wee pons in a Big Chess game so to speak. The Saudies all made a deal 40 ishyears ago to base a barrel of oil on the US dollar and the world moves on oil. Fracking is just getting the hard to get oil out and there is billions of it and they will control everyone, with the provibal "carrot in front of the donkey" Global sharing site's of information will break this cycle but not in my life I doubt, but always hope, Things like 3d metal printers will make it possible for people to be independent and still live with modern things. We just got one shop open in London Ontario Canada that anyone can pay to use,down load your program and your protype comes out the other end. It's not imposible to beat the controling rich ,but , people will have to resort back to older times with new teck.Modular building platforms to work from and then custom it to your taste.Think Bently ,Pinniafreina,Dusenburg,Ford model T, basic rolling platform that any bodywork coud be attached too. Only 500% better platform to work from. The old UJM was just that and could be again,look at ducks and ktm trellis type frame excelent platform to work from for any eng/supsension. DISPOSABLE is no longer a option,or we we all be burried up to our neck in horse shit and plastic,europeans are way ahead and have been for decades,and I have always followed what is going on ,only time will tell if North Americans will wake up and get in the game. I have heated my house for the last 5 years for free ( almost cost about 50 bucks in gas to drive to get the wood from the local roofing company to get all the end cuts) so you CAN beat them at some things! And restoring/repairing a old vehicle is a great way to start,if youhave some skills and get creative,I like concours but tireing of them,only cause they get parked in museumes. Why build it if your not going to use it?
  18. dt502001 posted a topic in General
    I bought a new hammer, because I forgot my fave one in my tool box.Perfet hammer used to drive 1 nail in, on the end of my left thumb. Fuuuuuuuuuuuuck can be found somewhere in the field behind my house. First come first serve
  19. Thats what I thought the kill switch wired off the diagram would do nothing if the ignition switch is on or off it should intrupt the ignition swith circut an on,,, both wires from the kill swith attached to the black white wire would make it work.So cut the B/W wire(What ever colour it is on the bike) and hook the 2 wires from the kill switch inbetween that way it will work.And the spark will stop with the kill switch. Yes you need a regulator or you will boil your battery.
  20. The coil has to be grounded if the coil has 2 wires then 1 of them has to be grounded. The way you have it wired your battery power is going nowhere but to the switch,kinda pointless and will neve get charged,then again it's not doing anything so it dosen't need to be charged.But if your going to run a battery why not hook it up ? The battery does not feed the cdi the generator does.So I hope you didnt connect the battery to the black and black with white wire or you fried your cdi. One thing that has me a bit puzzled is the kill switch is in the off position but the ignition switch is in the run position,I would leave the kill switch out of the puzzel it's not needed,untill you have the bike running.I think the diagram is wrong.The kill switch in the run position would open the two wires to the cdi in this diagram not groundin the cdi or generator feild.But the ignition switch in the run position is grounding the black white wire Also you have not rectified or regulated the current or hooked up the lighting coil you will burn it out. I read your other post ,,no way to check a cdi. Best to keep all your post's together in one thread ask a mod to move them. Airhead this might be part of the otherguys problem with his 125 not having a permenet off on his bike if it was wired off this diagram? I will look at this later ,but it should be close to a 175 diagram. What do you think?
  21. Search home made carb ballencer here and on utube,basicaly a hose ,a yard stick and some 2t oil and you can make a mamometer to sync the carbs As for cleaning dissasemble soak in carb cleaner,blow clean with compressed air ,set float height and pilot screw,take note of pilot screw turns to bottom befor disasembling. If it's only running on 3 then a compression test is in order.
  22. dt502001 replied to blackhat250's topic in Random
    Sucks we don't ever see the price drop at the pumps in relation to what it should be,they certianly are quick to raise the price,but ,then feed us bs about how the gas your buying today was made from oil bought weeks ago. Oil production is a big part Of the GDP so the arabs are keeping the dollar down by droping the price,not such a bad thing makes our products cheaper to make,but stagnates growth.Ie wages. What one hand givith the other takeith price of Hydro just went up nov 1st here so no win situation save a dime here spend it overthere.What has me even madder is the Ontarion government is running a 30 million campane to tell us it's all good for us,that hydro is cheap,FMe the robbing bastereds the cost of the hydro is 45% of the bill the 55% rest is tax. We are FRACKING destroying a once beautiful country,if you have seen the oil fields out west it's devestating 100 million acres leveled a striped of trees,billions of gallons of drinking water contaminated. You guys can complain about how much you pay for gas but,in some ways you deserve it ,running all you vehicles on what we call high test. Are cars run on 87 octain 10 -15 % blend of ethonal and as high as 85% ethonal our hight test is 91 octain,if you want better than that here you have to buy race fuel,so considering your getting a much more refined fuel the price is in line with cost of production. We dont need cheaper gas what we need is better fuels,like hemp fuel,the eng that runs on salt water in mass cheap production,from renewable sources,better batteries that can go farther,better solar pannels to charge the batteries faster.Once the need for oil is removed then the price will drop and all us motor heads will be able to enjoy our gass gusseling toys. But then you will be complaing that your solar car runs for free and you have to buy gas for your toys
  23. We got them here as the "fazer" yams attempt to market off the Vmax didn't sell well at all.
  24. LOL 79 anyother bets? One tooth won't make much difference, -1,14t =3.142 :1 , stock15t=2.933 : 1, +1 16t =2.75 : 1 for the extra 10 bucks you should have ordered a 16tooth as well and only paid 1 shipping.
  25. Welcome ,first order is to pick up a manual.
