Twoesme
Everything posted by Twoesme
  1. Twoesme posted a topic in Yamaha Gallery
    Bought this xs 2 weeks ago for About £250 with new tyres,She was rattling her nuts off (tappets) when i rode her home. No front brake ,it was working but no bite on the disc This was the state under the seat Air filters were just as bad I adjusted the zorst a bit Chit or bust i went to work on her,Fixed the number plate down on the side and chopped the rear a bit and fitted cow horn style bars. But it did,nt look right More work to lift the zorst up Starting to take shape But still not right So back to the frame Getting there Still that zorts don't look right Nipped a bit more off it and fitted the rear muddy That zorst mun ..... Right its having it Thats the ticket Front muddy Lowering it more later. Cleaned up the front pads and disc ,also drilled some pretty holes in it . Now she stops . Bit of rattle can paint with fleck ,single seat and home made panels That zorst !! Better seat and battery /wire cover plate Got an oil leak behind the points on the cam seal .(the tic over lol) I advanced the timing ,and every other thing you coud do and its holding there at 2k revs but some times cuts out.used to it now . Got some cone filters on they'r way. new plugs/caps,she's had an oil change ,starts a lot better,more or less off the button now ,Rear shoes need changing next,Couple other jobs. But she's on the road . Zorst is now stone chip black,And i,ve added some black stipes to the panels. She rides tidy,but reving hard say in 3rd onwards it holds at about 6k revs for a while then pulls through right up to the red line ,Just holds there at 6k for some reason ? Plugs look a good color,Going to clean the carb out when the filters are back see if any jets are blocked and put an inline filter on. Also got my eye on a 400 motor but it aint got no carbs ,So hafto find out if the 250 carbs will work and if the down pipes will bolt straight on. Oh ! That zorst Ps how's Yamhead getting on ,I heard about his nasty crash if its the same Yank scott I know ....
  2. Hi all ,I,m two's from South wales uk.Current ride is an xs250 bobber "all my own work" Still in the add on stage ,Need few parts to finnish but its on the road,And out on regular ride-outs. Will bang up a few pics later on tonight of the chop build . Seen this forum come up whilst serching for the correct valve clearences ,Nice one .
