Carb adjustment (TDR 125 DT etc)
Sorted this out now, or it sorted itself out. Running well now, goes like stink.
I'll have a good look at those possible cracks tomorrow or Monday. Would it be the bigger screw in the middle then?
- yamaha dt125
Whilst using the throttle I'm experiencing some "bogging" after fitting the new throttle cable so I guess I need to adjust the carb in some way. It ticks over normally but struggles when the throttle is applied. I think it's the left-hand screw but not 100% sure. (crap picture courtesy of Apple iPhone)
TDR250 Standard Silencers
I found one new in Germany, for the right side, pricey though CLICKY
Changing policy, new bike...
My insurer (Hastings Direct) wouldn't let me switch from the SR 50 to my TDR 125 and stated that I needed 2 years NCD before they could insure me!! Claimed back some of the money and took my business elsewhere.
Throttle cable question - 1993 TDR 125
Wemoto didn't have them in stock and couldn't say for certain if one from the DT R would fit, so I took a chance and it does. Throttle is silky smooth now. Bugger to change though, panels off, fuel tank etc. But at least now I know a bit more about what's going on under the seat! Thanks for the advice.
yamaha dt parts
You can have the hangers and pegs from my TDR if they are any use to you. Pics are in my sig.
I'll ring 'em in the morning, cheers.
I'd looked at both site but they don't have the cable for the bike. I've just e-mailed Wemoto though to ask if they can suggest one from another model.
I'm looking for a new throttle cable for the above bike but I can't one that's for that specific model. Would anyone know if one from another bike would fit?
1993 TDR starting woes
Right, got it started. Only starts with the manual choke set on full though, turn this off and the engine revs it's nuts off. So I guess i need to adjust the idle screw but I'm not 100% which one it is. The big one in the middle or the little one on the left? It's a PHBH28 VS. I would upload a picture but can't for some reason.
Ignition Questions
I found these - XV 750 (92-96) XV 750 SE (81-83) Virago (92-95) Hope that's of some use.
I have spark AND the starter for some reason has even tried to run properly and almost started the bike. I've tried kicking over but it stil won't start though.
Given the choice would you wear a helmet?
I prefer to wear it and not need it rather than need it and not wear it!!
