???timing off???
I cleaned all carbs, replaced gas filter,and lines,and cleaned out vent,but found some rust in my tank not much but rust is rust,I will let you all know how it goes after cleaning tank. thanks so much for all your help
???timing off???
Thanks alot guys I appreciate all the help. does any one know where I could find a used ignition box. there too expensive to buy new and I'm not having much luck finding a used one around here.I was told that was what I needed to fix my timing problem.
???timing off???
I have A 1986 fj-1200 I believe the timing is off but my question is would the timing being off cause my bike to run ok for about 20 minutes then die and after sitting for about an hour it will start back up and run for another 20 minutes? Or would this possibly be a completey different problem?
fj1200 front end shaking
recently I have notice that when doing only 25-30 mph the front wheel shakes and is all over the road.The only thing I found wrong was 1 fork seal was leaking. Can anyone tell me if that seal would cause that or any other ideas any help would be appreciated? thanks in advance Josh
fluids for my bike
thank you you were very clear and I apppriciate the help and it is a small cooler in the front of the bike but its at the top of the engine
fluids for my bike
I recently bought this bike and it had no fluids in it. I put in oil,and blead the breaks.But my question is what kind of fluid do I put in the master cylinder for my clutch? It says dot3 brake fluid on the cap but that doesn't sound right,does it? And do I need to put anything in the oil cooler? I know I sound like I shouldnt even be on a bike having to ask these questions it's just been a long while since i've messed with one. Any help would be greatly appreciated. My bike is A 86 FJ-1200fluids for my bike
how much oil do i need
i just bought a 1986 fj1200 and it has no fluids in it how many quarts of oil do i need to put in it?
Josh
Joined
Last visited
