FJ12SP
Everything posted by FJ12SP
  1. FJ12SP replied to Gismo's topic in The Bar
    Hi Gizmo If you havn't already have a look here its a wealth of info for the FJR. http://www.fjfjrbiker.co.uk/fj_forum/ Adam.
  2. Yes I must agree it sounds very much like a shagged piston causing crankcase pressue, you will need to do a compression test and compare your findings with the bikes spec. As for not starting if you have shagged pistons/rings the plugs have probably oiled up. Pull them out have a look if they are black and oily its going to cost you. Adam.
  3. FJ12SP replied to The Beard's topic in General
    There was a recall for the FJR regarding the TPS (Throtle Position sensor) this sounds like your problem. I would phone yamaha with your frame number and check that its been done. also visit here for more details http://www.fjclub.co.uk/ Adam.
  4. FJ12SP replied to Josh's topic in Naked
    I had a similar problem on my FJ and I found that when I replaced the O/E rear shock the problem disapeared. If I tried to take my hands of the bars at any speed the bars would flap into a tank slapper. I must confess that I was very suprised that the rear shocker could cause this but after recent discusion with the FJ owners club it was a reasonably common fault. Are you running a O/E shock or have you upgraded as I would guess that a 21 year old FJ's back shock would be shot, they did not last more than 30,000 miles. Hope this helps
  5. FJ12SP replied to pistonbroke's topic in The Bar
    Dan Try the ACE cafe on the first friday of the month (Every friday is bike night) all the boys come out to play, you could then ask around. Adam.
  6. FJ12SP replied to tat2bear's topic in The Bar
    Hi Martyn I doubt very much that its an oil problem, the oil warning light will always come on briefly when you turn the ignition on. If you have the kill switch off the oil light will iluminate when you push the start button but the engine will not turn over. Try cleaning the kill switch contacts. Other than that I suspect an electrical problem, could be the main earth connector this is prone to problems on the FJ's. It's located at the rear of the engine block ( It's a right B***ard to get at). Hope this helps let us know how you get on. Adam.
  7. FJ12SP replied to pistonbroke's topic in The Bar
    Well Dan if you added your location in your profile it would be easy for peeps to let you know. Have fun on that bad bike. Adam.
  8. FJ12SP replied to pistonbroke's topic in The Bar
    Nice One ! Enjoy! Adam.
  9. Hi FJ yes she's a 91 3XW, hardly any standard bit left though Adam.
  10. Oil & Filter every 3000, Yam say every 6000 but it don't cost much to keep her fresh ! Adam.
  11. Well here she is all shook down ready for the summer (if we get one !) Adam.
  12. This chap has done some great work for a number of my friends Tony Archer seats Unit 7 Riverside works Bradley Mill Road Huddersfield Hd1 6pq Tel.01484 536832 Adam.
  13. I think this is an easy one. You are either putting it into gear with the side stand down or the side stand sensor is U/S. Adam.
  14. Wow there is two completly differant bikes, I own a FJ so I would look for on the FJ 1) Fork Seals , FJ's eat them. 2)Clutch slave seals , ditto. 3)ABS warning light should extinguish as soon as bike starts, if flashing there are problems (Electrical) but they will still operate fine. Very expensive to replace/repair. I have junked mine. 4) Rear shock and suspension linkage/often negleted. 5) Wheel/head bearings. 6) Front calipers sieze. and all the usall stuff, the Engine is pretty unbreakable and with just 30k it's only just run in. Adam.
  15. Hi The Ron Haslam race school is an excelent way of learning about your bikes capabilitys (and yours). It will certainly increase your confidence/ability. As for the Crash helmet differant helmets suit differant peeps, but as I said before it,s your HEAD. Enjoy. Adam.
  16. Great choice (Yamaha) as for it being quick , theres no such thing as a slow bike !. Do you need a new helmet ? it's your head and only you can decide, but its your life insurance. Enjoy the buzz and as Yamhead says time in the saddle is what counts. Adam.
  17. Hi Max I am just down the road from U , look out for me on my FJ12 special. Adam.
  18. FJ12SP replied to kev's topic in General
    Nope that don't work (Link). Adam.
  19. Hi It could be lots of reasons, the FJ1200 runs hot anyway but I suggest a good service, oil & Filter change aswell as getting the carbs Synched in, you might also want to check the plugs to see if it's running lean or rich. Depending on the condition that you are running the bike , you might like to consider a lighter oil. The 1200 engine is prone to a tick from the engine ! Adam.
  20. Engine's are pretty bullet proof, but as you already stated 2nd gear pops out on early models & the clutch slave seals are prone to blowing. Also check Fork seals and rear shock and linkages. but apart from that these beast are renowend for going on forever. Adam.
  21. Got a similar problem with my FJ1200, I have exhaust and oil coming from my crankcase breather. I did a compresion test and found that the Rings on pot 1 were U/S. Have at the moment got the barrels off getting honed and a new piston Kit. I do not run an airbox (S&B indi filters) so I have a crankcase Filter (Instead of running up into airbox) but the XJR lump is the same as the FJ. What you are experiancing is crank case pressure (Not oil pressure) this is probably caused by broken or sticking piston rings. Hope this helps Adam.
  22. Sounds very much like a blown head gasket, if there is a lot of white smoke. The head gasket is blowing down the cam chain guide. This will also cause the oil to smell of fuel as gas will be being pushed down the cam chain slot into the crank. Adam.
  23. FJ12SP replied to yamayetty's topic in The Bar
    Not so loud please !!
  24. Hi Has it a fuel pump as I had a similar problem with my FJ12, the fuel pump relay was U/S would run fine and then it appeared to run out of juice. Turned it off then on again all was fine for another few miles and then it happened again. Adam.
  25. FJ12SP posted a topic in The Bar
    Hi Just joined , I own a 91 FJ1200 that I have re-built to my own tastes. Spent all winter farkling. Adam.
