xj600 raise
Its Shorter Dog Bones you want not longer, very easy to make you can buy the flat bar from B&Q. Just shorten by 10mm will raise the back a lot. Adam.
Fuel pump alternative
Hi I believe pre injection R1 pumps will fit (They have slightly differant angle take off) also FJ1200 pumps will fit again the fuel take offs are slightly differant but they can be modded to fit. I think that you will find that any Yamaha fuel pump (12v) can be adapted to fit. My Yam FJ1200 has a Mistabushi fuel pump fited. Adam.
XJ900F clutch problem
Did you soak the new clutch plates in oil before fitting ? As its a wet clutch it relys on the clutch plates being oiled (Wet), when re-assembling a wet clutch its always best to soak the plates for at least a few hours preferable over night. Also oil types have a critical bearing on the operation of wet clutches. Are you running the appropriate oil for your M/C. Dry plates will cause clutch drag as they are not realeasing proprtly, If my bike is left to stand for any length of time I will get initial clutch drag. Start the engine aqnd warm up Pull the clutch in several times with out engaging a gear this might help. Adam.
- comfy seats?
1986 fj 1200 anti dive
Its no problem to blank of the Anti dive, and just run straight hoses from master cylinder to calipers. An even better solution is to transplant a later model front end in. Adam.
Spares For FJ1200 wanted
The FJ Owners club is a good starting point. Adam.
Clutch master and slave cylinder seals
If you are continualy blowing slave cylinder seals i would hazard a guess that the slave is to worn and you need a new one. When you replace the seals are you cleaning the slave piston and bore with a scotchbrite pad and re-newing the fluids(anything else will damage the piston & bore) You can change the master cylinder for a more recent model (FJR,XJR, Fazer ect) you will gwet a better clutch pull with one of these. These can be picked up nearly as cheaply as the repair kits from Ebay. Have you joined the FJ owners club, you can purchase a wide range of parts from them and get advice over the phone for a yearly sub of i think £17 I have a very good standard clutch master you can have for a few beer tokens, just let me know. Adam.
carb swap on FJ1200
Hi Robb The carbs will not fit due to the fact that the 1100 had a gravity/vacum feed petrol line, and the 1200 run a petrol pump, you will have trouble stopping the petrol running out of the overflow. The pipes on the other hand are a straight swap, but you might have to play around a bit with the silencer hanger. Sorry re-read your post and i see that you have a 86, in that case I think that your 12 has no petrol pump and a swap to the 1100 carbs is possible. Adam.
fj1200.. just bought got a few teething probs.. if any one can help.. headlight and tail light stay on when light switches are off..
Ebay is your best bet they range in price from £20 up to £75, a Yam dealer will want £300 + All models use the same genny, also Yam XJR gennys fit. Adam.
Are you locking the steering when turning the bike off ? If so you are turning the key to far and activating the parking lights. here is a great place for info on the FJ Adam.
XJ600 vibration!
Carbs need to be balanced, valve clearances need to be checked, if both of these are done you will have no significant vibes ! Adam.
fj1200
I think FJ1100 fit but if you join the club you can buy a new rear from them Adam.
1998 R1 faulty brake light
Much better option is to junk the switch and fit a Banjo Pressure switch. Here http://www.demon-tweeks.co.uk/Motorcycle/Brakes/Brake_Accessories/Goodridge_Banjo_Bolt_Brake_Light_Switch/392/3646 Adam.
"Any ideas and could I repair this fault myself.." Rear brake light switch & yes. Adam.
Yamaha FJ1200A
Hi this is quit a common problem on the FJ,s You will need to take the carbs off, remove all parts and get them cleaned Ultrasonicly. Then re-build the float bowls with new needle valves and washers, taking care that the floats are at the correct hight. Some times when they are leaking you can give them a good tap (Float bowls) with a screw driver and that will stop it, but its probabale worn float valves (remember the bikes 20years old) Have a look here lots of help available. http://www.fjfjrbiker.co.uk/index.php Anfd join the club here Adam.
FJ12SP
Joined
Last visited
