srussell
Everything posted by srussell
  1. Thanks for your response fellas, my headlight lens is glass,I will enquire with the seller of HID Whether it will suit. I have seen the kit on other bikes and the light output is incredible. thanks again.
  2. Hi there, i'm thinking of installing a HID kit to my TRX. The headlight is quite poor and this kit would make me more visible to other drivers. Has anyone out there installed a kit on their TRX and can it be done successfully. Can anyone help. Cheers Steve.
  3. Thanks for reply, just checked trx workshop manual. M/C bore 15.8mm. so whether I can use existing M/C with blue spot calipers. Maybe not because bores don"t match.
  4. Great thanks for that info Drewpy.
  5. Hi there, I own a TRX 850 and am interested in fitting some blue spot front calipers. Is it just a matter of installing callipers or do you need to change master cylinder as well. I believe calipers off an R1 or R6 1999 to 2002 are able to bolt straight on. I"m hoping someone may be able to help. Regards Steve.
  6. Hi there, I"ve just joined as a new member. I hope someone can help me. I own a TRX 850 and interested in fitting some Blue Spot callipers. Is it just a matter of bolting the callipers on or do you need to replace brake lines and master cylinder. I believe the callipers off an R6 1999 to 2002 model is the way to go. Regards Steve.
