spurs59
Everything posted by spurs59
  1. spurs59 replied to spurs59's topic in Naked
    would you kindly explain how the jetting is done has these bikes have no carbs
  2. spurs59 replied to spurs59's topic in Naked
    if fitting a k@n filter would I need to get the fuel ratio fixed or is that only done when adding a scorpion exhaust has well
  3. spurs59 posted a topic in Naked
    which is the best air filter for the yzf 125r
  4. can you get aftermarket hand guards for the dtr sm or do you have to buy original only
  5. did you buy the rethnal bar pad from ebay too,i would have to find out if the bars you bought would fit my bike
  6. im trying to source some blue handlebars for my dtr sm but cannot seem to find any,does anyone know where i can purchase some.
  7. i am going to replace my dep exhaust with the standard one that iv'e had de-restricted,im also going to change the end can but dont know which one to get,any recommendations.
  8. does it matter if you earth the green and black wire behind the speedo clocks on the dtr 125x to the frame or battery or is it to the frame only
  9. where is the cdi unit situated on the dtr sm
  10. i'd like to hear other folks views
  11. so you recommend i keep the standard sprockets?
  12. im led to beleive that by using a smaller back sprocket i will get more top end speed,how many teeth do i need to go down on from the standard sprocket
  13. i have removed the cat from my standard dtr sm exhaust,once put on the bike should i get the same performance has the dep exhaust but with a different sound?
  14. my standard exhaust on the dtr sm does not have a spout ryan just a straight pipe the same has the dep,i think you could be refering to none sm dtr's
  15. is there a specific rubber joint for the dtr
  16. i would imagine this would work has i have it now?
  17. i cannot remember if there was one when the standard exhaust was on the bike but there was not when the bike shop fitted the dep exhaust.i noticed that once the dep exhaust was fitted that oil was leaking from where it joined the end can has it did not marrie up correctly,i has to put some gum gum round it and then a piece of rubber tubing held in place with two jubilee clips
  18. why did i not have this problem with the standard exhaust fitted.i did not have the problem with the cagiva mito,thats prob because the end can is lower down on the bike
  19. will a different end can sort the problem?
  20. not when your clothes are stinking of it its not
  21. my dtr sm came with a standard exhaust and dep end can,i had a dep exhaust fitted and ever since my jacket and if carrying a rucksack smell badly of oil after a ride out wether it be for 5 mins or an hour.does anyone else have this problem with the full dep system fitted?
  22. spurs59 replied to spurs59's topic in Yamaha Workshop
    i forgot to add that the bike is an 07 plate,is the cat still in the expansion chamber on this year?
  23. spurs59 posted a topic in Yamaha Workshop
    where is the cat converter on the standard exhaust for the yamaha dtr 125x sm,i want to remove it.
