spurs59
  1. spurs59 replied to spurs59's topic in Naked
    would you kindly explain how the jetting is done has these bikes have no carbs
  2. spurs59 replied to spurs59's topic in Naked
    if fitting a k@n filter would I need to get the fuel ratio fixed or is that only done when adding a scorpion exhaust has well
  3. spurs59 posted a topic in Naked
    which is the best air filter for the yzf 125r
  4. can you get aftermarket hand guards for the dtr sm or do you have to buy original only
  5. did you buy the rethnal bar pad from ebay too,i would have to find out if the bars you bought would fit my bike
  6. im trying to source some blue handlebars for my dtr sm but cannot seem to find any,does anyone know where i can purchase some.
  7. i am going to replace my dep exhaust with the standard one that iv'e had de-restricted,im also going to change the end can but dont know which one to get,any recommendations.
  8. does it matter if you earth the green and black wire behind the speedo clocks on the dtr 125x to the frame or battery or is it to the frame only
  9. where is the cdi unit situated on the dtr sm
  10. i'd like to hear other folks views
  11. so you recommend i keep the standard sprockets?
  12. im led to beleive that by using a smaller back sprocket i will get more top end speed,how many teeth do i need to go down on from the standard sprocket
  13. i have removed the cat from my standard dtr sm exhaust,once put on the bike should i get the same performance has the dep exhaust but with a different sound?
  14. my standard exhaust on the dtr sm does not have a spout ryan just a straight pipe the same has the dep,i think you could be refering to none sm dtr's
