yamyam thank you maam
Everything posted by yamyam thank you maam
  1. wow thats gone over my head lol i have changed the voltage regulator and its still there the battery is nearly new too no sure what to check next or where either ???
  2. have you considerd your oil crank pressure maybe you need new seals could be that also check your reed valve and coil output sometimes coils work great for a period but soon weaken after running a short while if they are on there way out also maybe check youre exhaust isnt fould up with carbon
  3. hya people i wonder if there is anyone who can pinpoint my problem the problem is always there but is really noticeable at night.. while riding my electrics surge all my lights including dash headlight become really bright for a few seconds then return to normal and sometimes they dim below normal level too it fluctuates all the time would i be right in thinking it could be the voltage regulator or is there any other possibilitys ??? because i dont really want to go on an expensive fault finding saga i hope there is a member who is better on electrical than me any help would be really appreciated ps i get the feeling people laugh at my xj because its often termed as a divvy and i gotta say its starting to put me off it now shame really cause i like it even though its a bit dated compared to some like the bandit
  4. hy all i wonder if anyone out there could tell me if an xj600 diversion tank will also fit the 900 diversion any help would be appreciated as im selling one on ebay many thanks ...vinny
  5. wow that last piece made me sound like dr evil lol
  6. cheap it is i swapped an rxs100 for it and insurance was third party £70.00 all in. 1st 2nd an 3rd gear still put a grin on my face but i suppose it will wear off as you all know the hunger for power normally tends to dominate the list of prioritys
  7. i bought an xj600 diversion and after reading the reviews i found it to be a fairly fast comfortable user friendly bike so why do people slag them off so much i know it doesnt perform like an r1 type of bike but its good for someone on a budget like me and apart from slightly lacking the gut wrenching accelaration like some others i find it hard to pick any faults with it so whats the beef why do people seem to hate them ?? do you!!
  8. some people are so destructive waste of a perfectly good bike innit
  9. http://www.livevideo.com/media/playvideo_f...0EDCE43E260BFCC
  10. hya yes it sounds like the carbs need balancing make sure your points are gapped correctly and i would replace the float needle valve "the thing with the spring" as once they play up you got no choice but to replace check your carb mounts arent split or leaking and your throttle slides are moving freely also check your float level as well the specs should be in the manual . it def sounds like your carbs are at fault here though did you buy a decent carb cleaner so you could blast through all the channels inside also if you have any rubber diaphrams check them for splits and pinholes hope that helps all the best ..vinny
  11. check an make sure the clutch cable is well lubed and adjusted correctly and you have the right grade of engine oil an if that fails it down to you clutch springs being week or your clutch is worn
  12. 45
    yamyam thank you maam replied to Section 8's topic in The Bar
    so o guess that means wese not on da same stack doooood
  13. 45
    anything to do with old spice ?? or posh spice maybe mixed spice ?? they are the only spices i know anyway whats wrong with robbie williams great music and a true british artist if people didnt like him he wouldnt sell, nobody new your spice man but im sure people know robbie williams
  14. indicator relay is under the tank an just near the head stock
  15. dont come near me osama binhead or i may pop a cap
  16. yamyam thank you maam replied to Andrey K's topic in The Bar
    oh silly me you have a job already WORK HARDER
  17. they are trying to price us off the roads arent they why do they always punish the working people at the end of the day whats the point in working to just break even may as well stay in bed as there is no reward apart from youre self respect
  18. yamyam thank you maam replied to Andrey K's topic in The Bar
    yeah right mate if you can ride a bike you can get a job and save like everyone else lots of people love bikes but cant afford one get a moped !!
  19. its ok they gave me the pre diversion ones
  20. can some one help me out her as i bought a set of fork dust seals for my xj and they dont fit the dealer said they are the right ones and i know the forks are original i did a parts check online and found that they fit a yx600a and a xv750k but i cant find anything about them being for my bike- the part number is 33m-23144-00 is there anyone who could do a parts check for me to see if they are the dust seals for my xj 600s diversion 1992 as they def do not fit
  21. i would get the voltage regulator checked sounds like it may be linked if its frying the rectifier and battery
  22. here is the link http://www.motorcyclespecs.co.za/video_clips.htm just copy and paste on your address bar and enjoy
  23. how the ~~::@}@{: do i put pictures from my pc on this board any help will be welcomed dam pcs bring back the 60s especially the mini skirts
  24. what happend to it crash or I R A bomber
  25. flasher relays sometimes gum up a bit open it up and spray some wd40 in them
