Steven Klimaszewski
  1. Steven Klimaszewski changed their profile photo
  2. also i have to extra wires comeing out off cdi box solid black and a black with white strip i know nothing about the wireing on this cause when i got it it was stripd down no kill switch ans no key/inignition some told me that thead light has to be hooked up and new wire harness for bike to work sounds far out there but if you give me your email i can show you what iam working with never worked on a dirt bike befor so not sure where to start tryin to find a ohms meter to thanks
  3. mine is a 1980 dt175g it has been stipd down befor i got it it no battery lights ect. even the main switch that the key goes in is gone no kill switch ... there is a orange wire that come out of the black box to the coil i think its a cdi box asy from the diagram i looked at i dont have a omhs meter so i un cllip the orange wire n get shock through it but not much the hard i kick it over the more shock it gave my fingers not sure whats up iam lost
  4. ya it ran before it gets gas from carb has real good compresion new gaskets does not start with any type of prime it has spark but looks like a small spark my lawnmower show more spark than my bike i test the plug in the lawn more to see how it sparks same color but smaller on the dirt bike its just a push mower i tryd running with the bike and releasing the clutch nothing not even a sound of wanting to fire only thing i can think of is electrical or spark i get shock from the spark plug but not enough to make me take my finger off i tested the wire going to the coils from the black box that gives me a little shock bout as much as the plug does dont know where to start stator or coil i can send you pics if you wanna see the bike thanks for any info you can give thanks
  5. i have a 1980 yamaha dt 175 i change the rings and pistons it has very good compression and spark but wont start i tryd starting fluid the carb is new and is getting gas to the to the cylinder i tought maybe it could be getting weak spark what would it most like be ign coil or stator also the bike has been complete stripd no kill switch and the and sthe on off switch up put the key n is gone to i think its calld the MAIN SWCH STRGLCK could that cause weak spark and can you rebuild a coil ur self not sure what to do i got this bike from a friend who past away i he never had it running would love to get it back running any help would be much appricated.
