wick112
Everything posted by wick112
  1. I'm now able to shift gears! Now the only problem I have is that I can't get it to shift back into neutral while it's running. Once I turn off the bike it shifts in to neutral just fine. Any ideas?
  2. figured it out once I took the the whole basket off. The bearings were stuck.
  3. I'm not sure. I'll check in the morning. If so what do I need to do?
  4. It's been sitting at least 15 years! I pulled the plates off and separated them. I finally got both push rods out and the ball. Put it all back together and still getting the same thing. It seems to go thru the gears fine. I would think if the transmission was locked up I wouldn't be able to get it back in neutral. I don't know what to try next
  5. I've got a 73 at3 125 that runs great but won't go into gear. I've pulled both side covers off. I can get the clutch push rod out on the right side (I'm almost positive it's a two piece rod with a ball) but the other rod seems to be stuck. If I turn the the adjustment screw it appears to push the rod some. Am I missing something? Is there anything else that could be holding the rod in place? any help would be great!
