mr wilks
Everything posted by mr wilks
  1. dont worry about the mpg mate just screw it like you would your lass!!!
  2. Hi all read my post (last week sometime) BLEED BRAKES.
  3. mr wilks replied to St0fxxx's topic in The Bar
    hi its usually the power valve that cokes up
  4. thanks all thats great
  5. Hi ive had same problem in the past and found there are two ways to bleed the brakes 1/ use a brake bleed syringe (ebay about £5.00) Take top off of master cylinder crack open bleed nipple push syringe on to bleed nipple and draw out all the fluid . then fill syringe with fluid and gently squeeze in fluid keeping eye on master cylinder level 2/ remove calliper hold it above resevoire and put something between the pads (thicker than the disc ie tyre lever.Either ways work !!!
  6. Hi to every one im a newbi to this site and i need help!! im in the process of buying a dt125lc engine but im not sure what year it is mk2/3 The engine number starts with 35A .Can anyone help???
