Dtlc3
Everything posted by Dtlc3
  1. The clutch arm when at this point and you try and move it forward it won't budge it's stuck solid. This is where the clutch arm goes into should there be a rod poking out of the hole ?? Few pics Iv taken if they work.
  2. Ok will try and get some pics up wen I work our how lol once again sorry airhead
  3. Ok many opligies, maybe I took offence at something I shouldn't have, my bad, and I agree my description haven't been exactly great but that's the only way I could describe it, will try and post some pics when I find out how, airhead, many oppligies, my bad.
  4. Sorry
  5. I striped down the clutch etch all ok,then took clutch arm out wher the cable goes shon a torch down the hole and the is another hole inside, should there be something poking out the hole?? Cheers
  6. Ok mate will get on it and update later cheers
  7. And airhead no haven't had the clutch off at all just the casing could the rid that goes through get rusted in place ? Cheers
  8. Well where it had been sat outside it had water in the clutch it was an oil and water mix the oil was dark black,also no oil in ATM incase I need to take the cover back off cheers
  9. It's a 1987 dt 125 lc3 The clutch arm is on the maganito side and the clutch basket is on the opposite side, so there must be a rod or something I between the 2 ?????
  10. Sorry my description a bit rubbish, wen it gets the the point where it meets the restiance then it won't budge past that point it's like somethings seized, no matter how much force you put behind it it won't move ?
  11. Evning all. Right my first problem is I can't pull the clutch in the bike I got of my brother had been sat outside for a good few months I'd say 6-8 I thought he clutch cable was seized so bought a new one. Then thought the clutch arm that the cable attaches to was seized. This is wear it gets strange you can move the arm about 180 degrees then it will stop solid a a certain point going in either direction. Anyone got any idias?.
  12. It's also advisable to check all your lights and horn before u ride the bike I used to check mine every few days or so,last thing u want is to end up with points etch,it takes about 2 mins,don't forget to check your brake fluid level,and NEVER polish your seat just wash it down with a damp cloth. Don't use wax or back to black on it etch. It makes the seat slippery, and you will slide about.
  13. Dtlc3 posted a topic in The Bar
    Hi all, Jw if anyone else on here also owned a 1987 dt125. I ask as I'm after some up close pictured, ie both sides, front and back as I want to see ways missing of mine, can anyone help???? Cheers
  14. Cheers
  15. I think ( dt125) needs some English lessons. I also own a mobylette n40 50cc, they other day after me dad fiddled with the chain it did 95 mph,lmao 125+ mph 'on a dt, you must have to replace the piston every day,me thinks u should lay off the crack!
  16. Hi all, jw if anyone had a repair manual for an 87 dt 125 that they could email me a cop of ???? Cheers
  17. Cheers mate
  18. Dtlc3 replied to Dtlc3's topic in The Bar
    Hi mate how do I contact him ?? Cheers
  19. Dtlc3 replied to St0fxxx's topic in The Bar
    Sorry the one that comes of the engine,
  20. Dtlc3 replied to St0fxxx's topic in The Bar
    IMO those things never work,for the price they cost your better of doing the old school method and set fire to it, Take the silencer off and get a soft faced hammer DONT USE A METAL ON.and gently tap around the silencer body this will remove the loose carbon.and then poor a small amount of petrol or paraffin, down the silencer, then set fire to it, don't go mad with the fuel just do small amounts at a time,also you will want a one of those BBQ lighter one of those long reach ones,,also u might want some gloves can get a bit messy,also don't look down either end of the silencer wen your burning the coke out.and it will get hot.hope this helps.
  21. Dtlc3 replied to Dtlc3's topic in The Bar
    Hi there I'm in burnham on sea mate.cheers
  22. Dtlc3 replied to Dtlc3's topic in The Bar
    Hi there, ummm I'd like to find out the reg number so I can do a hpi or similar to find out the history of it cheers
  23. Dtlc3 posted a topic in The Bar
    Hi all, I'm in need of a bit of help with my dt.i need to buy some parts for it,but I'm unsure of the exact year ( its been used a field bike The fame number starts 35a......, if any one could tell me the exact years, that would be greatly appreciated. Also can anyone on here find information using frame numbers, I have a 9 digit frame number.im trying to find out the reg, ????? Cheers
  24. Hi to all, My name is Stuart. My latest project is a Yamaha dt 125 lc 3. I look forward to meeting fellow members.
