Dtlc3
Everything posted by Dtlc3
  1. Dtlc3 replied to drewpy's topic in Video Section
    1 he has a mullet! 2 he was going through his cum faces. 3 he has a mullet!
  2. The pipe going from the intake is the vacume for the fuel pump, Also Check that you are getting a spark from both plugs, and check they are gapped correctly, Have you changed anything before this happend ????
  3. There pretty cool little bikes,my first legal bike was a Honda c90, I loved it I wish I never sold it now,, Was looking at getting another one but there fetching silly money now.
  4. It very compfy lol
  5. It's a 1974 mobylette n40,just needs cables and the correct carb, iv been trying to find the correct carb for nearly a year, to say there like rocking horse shit would apt, I like old and interesting bike and cars, iv also got a 1984 mk2 golf,with a genuine 45.000 miles.
  6. Hi all thought I would post some pictures of my latest project. Pictures not very good. It's not a Yamaha but ths was my last project Enjoy
  7. Ok mate no worries will check that Tommorow and update cheers
  8. How does the fuel get from the bowl to the engine what jet does it use. Also I bought 10 cheap tins of carb cleaner those 99p store ones drilled a hole in each tin and then emptyed the contents into a bown.anyway there was enough to cover the whole carb so it's been soaking in that all day so should be a bit cleaner with any luck.
  9. Lol yea it is in a sorry state. I don't think that pilot jet will ever come out.I'm not really sure what else to do
  10. I might try and get another carb or find someone on here that's selling one as I think mine is kaput lol
  11. Hi mate, the fuel is getting to the bowl and it's going into the bowl Cus the fuel I was putting in was coming out the drain hole, untill I adjusted the float height, Second the choke does move freely but, it's very loose, when I pull the choke out and go to kick it over once then the chock will go back in, it's very loose, cheers
  12. It's the one in the middle where the the throttle slide needle sits
  13. Hi there iv cleaned all the jets as much as poss the only one I can get out is the one where the throttle slide needle sits will upload a pic
  14. It's getting to the float bowl. Just not getting past that point?.
  15. Yea made up a temp fuel tank,so defo fuel getting to the carb
  16. Cheers mate.nearly got the bike running,just got to sort the carb and no fuel is getting into the engine. Even tho iv cleaned the carb twice,and blown it through with an airline.
  17. Hi can anyone tell me the size of the exhaust stude for a 1987 Yamaha dt 125 lc cheers
  18. Hi there just like to thank you for helping me sort my clutch out, it is now fully working Cheers.
  19. Dtlc3 replied to dpreece's topic in Yamaha Workshop
    Depends how good you are with a spray can,, Your better off getting yourself a few small boxes and stripping the bike down, also get yourself a manual, take loads of photos of it so if you get stuck you can relate to the photo,
  20. I use pickaling viniger to clean dirty rusty bike parts, for light rust I leave it in there 1-2 days. For heavy rust it takes a while like more like 2-4 days, also for better results iv put malasis in the mix, iv also used soda crystals, but add the crystals slowly as it foams a little when you first put the crystals in, it takes a while to clean but it's cheap
  21. Is that just normal engine oil like this stuff 310355196240 on eBay,or can you recommend some that I could use ?? Cheers
  22. I'm not sure if it is there or not,the pointer on the clutch arm is lighned up with the mark on te casing under the carb,I can't adjust the rod that goes trough the pressure plate,so if the ball bearing is in there then not sure what's up with it would sod pictures be of any help to you? Cheers
  23. How big is the ball bearing is it the same size as the ones in the steering stem or is it bigger or smaller? Cheers
  24. Update: Put the clutch arm facing the right way, and got the clutch to function of sorts, when you pull the clutch lever in it will move the rod that goes through the clutch pressure plate, but it won't move the pressure plate out to disingauge the clutch, iv adjusted the rod in as far as it will go, any thoughts ???
  25. Hi there yea I have the spring just not put it on ATM,ant now it all becomes clear, I will investigate for the rod.thankyou airhead
