Sacha
YOC Member
Everything posted by Sacha
  1. Sacha replied to Sacha's topic in The Bar
    Well... I'm not sure. That is the trouble. The Clymer manual has schematics for earlier and later type systems (some show a voltage regulator and others don't). I think I'll do as AJ suggested and follow the wiring to see if there is one. I did get the new headlight assembly installed and when I tested to make sure it worked, I noticed the light seems to flicker quite a bit with any change in idle. Do you think this is a voltage regulation issue or grounding issue? Maybe my best bet is to take it in (I know just enough to make a mess I'm sure). Thanks for all of your help though!!
  2. Sacha replied to Sacha's topic in The Bar
    Okay, so I got the new headlight assembly, but I can't find the voltage regulator. My Clymer manual tells me how to test it, but not where to find it. Is this something I should leave to a professional? My husband has a Fluke meter and I'm sure we could measure the output voltage, but I don't want to start tearing things apart without a clue. Any suggestions are greatly appreciated (as always).
  3. Wow. I guess I should have read the subject line. Sorry thought you were trying to post it in the forum.
  4. Sacha replied to Sacha's topic in The Bar
    You're absolutely right though. I've been wondering why the lamp was out myself. I thought I'd see how the new bulb does, and then go from there. But after reading your post I think I will look into the electrical system too! You are so awesome for giving me a heads-up. I really appreciate it.
  5. How are you trying to post it? Are you trying to post a reply in a forum or start a new discussion? Is it a link? an image?
  6. Sacha replied to Sacha's topic in The Bar
    Good news! The gentleman from NW Vintage Cycle parts has a 6V bulb to go with the assembly he suggested. woo-hoo! I'm getting a new headlight.
  7. Sacha replied to Sacha's topic in The Bar
    Hi AJ, Thank you so much for the info! I suppose I should have done a search to see if anyone had already posted about it (sorry). I will look at those links and get my headlight replaced. You were right about the clear tube too! I've got it all hooked back up and threaded through the frame and out to the road. Thanks again for taking time to help this newbie.
  8. Sacha posted a topic in The Bar
    The headlight on my 1972 G7S was burned out when I bought it. It's a sealed beam lamp and the part is no longer available. A guy at NW Vintage Cycle Parts said people are using the headlight from a 1968 YG5T. My original headlight is a 6V/15W and the replacement is a 12V/25W. Is that going to cause problems? Also, when I checked my battery I found a clear tube in the battery compartment. The tube is not hooked up to anything. It was just threaded through the compartment. I haven't found any mention of it in either the rider's manual or the Clymer manual. Does anyone here know what it might be? Thanks!
  9. LMAO - I was a bit slow on the uptake for that one wasn't I?
  10. Oh no! I seriously hope that's not the case with mine. That would not be good. How do I test it to make sure it's working? On a happier note, I got my new rider's manual today... it's teeny-tiny so I've already read through it (a couple times). I'm sure you've all seen how little the manual is, but I included a pic next to the Clymer manual just for fun. And now back to bad news... my headlight was burned out so I've been searching for a replacement. It turns out it's nearly impossible to get (and it's sealed). I found a place (NW Vintage Cycle Parts) in Oregon with a knowledgeable person. He said people are using the headlight from a 1968 YG5T (funny that the '68 is still available, but not the '72). Anyway, my old headlight is a 6V/15W and this new one is a 12V/25W. Will that be problematic? One other question... in checking my battery level I noticed a clear tube in the battery compartment that's not hooked up to anything. I haven't found any mention of it in either the rider's manual or the Clymer manual. Does anyone here know what it might be? Thanks!!
  11. Awesome! Rozzers... I'll have to use that. I don't think anyone here will know what I'm talking about. And thanks for the info on the oil in the pipe. The bike has the autolube pump so I'm hoping it's getting the right mix. I'm excited to get the manual and learn as much as I can about it. I've always wanted to build a bike from scratch, but for the price on this one I just couldn't say no. Thanks!
  12. Sacha replied to ddlooping's topic in The Bar
    Awesome! I think I'll be looking into adding one of these. Thank you for being the innovator and guinea pig.
  13. Thanks Airhead! It's actually in really good shape - I think. Supposedly it only has around 500 original miles. Looks like it was laid down or just dropped at least once because the knob on the end of the clutch handle has been broken off. I do have a few concerns (although my husband tells me I tend to over-react). He and my dad tell me it's normal for 2 strokes to (oil) foul spark plugs, but I also just noticed oil in the exhaust pipe... wondering if that is a red flag. ? I am waiting on a manual from e-bay to see if maybe I've screwed up and been riding it with the choke on. The Clymer manual just hasn't told me much about my bike specifically. To name a couple of things, it doesn't mention the choke or the fuel petcock... I'm thinking O is for on and R is for reserve, but what is S? Maybe I've screwed up there. ? I guess that's probably why you're supposed to READ THE OWNER'S MANUAL, eh? (dummy me) And Nayruf, I'd say you've had a few bikes. I'm not sure what "rozzers" are, but I sure do like my little 80. She's perfect for me... not too much machine like some of the bikes out there. I can firmly plant both my feet (which makes me a helluva lot more comfortable) and I feel that if (when) I do drop her, I can pick her up by myself if it comes to it. Oh, and she brings plenty of smiles with her!
  14. Thanks nayruf! That's all I can do. I drive and ride defensively, you just can't tell with some people, and you're better safe than sorry. She's just a little 80cc... I was expecting to get laughed at. But for my first motorbike she's all I need to get back and forth.
  15. Sacha replied to ddlooping's topic in The Bar
    I'm listening... I don't have any insight, and am a bit late on the thread, but better late than never right? It's been an interesting read.
  16. Sacha replied to crtr's topic in The Bar
    This may be way off the mark... but have you tried penetrating oil? You'll have to soak it and let it sit (multiple times if necessary). Where the drain plug is underneath, you may have to soak a rag in it and wedge it around the plug to keep it soaking. I'm not sure how the oil plug is set up on your machine or if you have enough room to work with it, but have you tried a breaker bar? I would suggest a bolt remover, but it sounds like the head isn't stripped just that the threads are seized. Hopefully I'm not being overly-simple.
  17. Hello everyone! I am in Idaho (the potato state of America). I am new to the YOC... I actually registered right after I bought my 1972 Yamaha (last December), but have been über-swamped with school (currently working on my thesis for a Master's of Education in Instructional Technology)... long story longer... I am finally posting so I'm not considered a total "lurker". I've been trying to read all of the new member posts, and it sounds like such an interesting bunch. Can't wait to learn from all of the experience you have! This is my first motorcycle. Sorry about the blurry pic. I got her for $1000 from someone who's grandfather had her in the garage for years. She looks great, but I think she could use a little TLC. Got the Clymer manual, but am still looking for an actual owner's/rider's manual since the Clymer one doesn't seem to be very model-specific. She also needs a new headlight, and the horn stays on when it's wired. I'm hoping that I can get her all tuned up and with regular maintenance and care she'll last me a long time. The vin starts with G5, but from everything I've seen online I think she's a G7S. If anyone has any insight into the model please let me know. I haven't ridden for years, and usually only off-road then. So now I'm trying to get used to riding in traffic - people make me nervous. Thanks for putting together such a great resource!
