duro
  1. Don't think so. Their heads are very well recessed. Anyway, I cannot understand why BOTH them are so tight!
  2. Hi all. I have a somewhat strange problem. Today my wife falled and warped the instrument cluster of her '07 YBR125 (made in China). As it was an apparently simple task, I checked the .pdf shop manuals I have and it said that the headlight should be removed first to remove the instrument cluster. Problem is: undoing the two headlight holding screws... the inner nuts falled inside. The manual didn't mention the need for first opening the headlight body (and I trusted the manual as it seems so precise in everything!) Therefore, after succeeding in straighting up the instrument cluster bracket, now I've the problem of re-screwing the headlight to its place. Problem: there seems to be no way to open it to get access to the mounting nuts. There are two screws on the headlight body (below the mounting bolts' places) which should obviously be the way to open it but they seem totally rock solid! There was no way to undo them (I also used WD40). I fiddled with my big fingers inside the headlight body (getting in via the cables hole) and found that in correspondance of said screws the body seems totally closed, as if the screws get into some "fixed" nut. By the way, access to the inside of the headlight is necessary not only mount/unmount it but also to just change the bulb. Now I'm stuck with an unusable bike having its headlight dangling down (and I should change the bulb too, by the way). Help anybody?
  3. Hi all, I'm Carlo from northern Italy. I'm registering here for, besides my V-Strom, my family also has a YZ125 motard (my son's) and a YBR125 (my wife's).
