Adhamhski
  1. Hi Evereyone, Took my bike to the local dynojet on Saturday morning. The problem was being caused by my aftermarket delkevic downpipes. The jets had to drop down 6 sizes from 115 to 100. The carbs also got balanced. Wish I had went here in the first place as it would have saved me a couple hundred quid. Bike is running like a dream. Thanks for all the advice, it was appreciated. Cheers
  2. Thanks for the advice KirriePete and once again blackhat250. I'll pass this information on and see where it gets me. Fingers crossed, i'll keep you posted of any progress. Cheers
  3. I've posted my query on the workshop this afternoon. Thanks.
  4. Hi everyone, it's my first time using a forum. Recently bought a fzs 600 fazer 1998. I'm not that clued up on motorbikes so I apologies in advance if I write or ask a daft question. I'm having a problem with 3rd to 6th gear between 6 and 7000 rpm. When I'm in 3rd gear I can feather through 6 and 7000 rpm but the bike splutters and then seems to pull through. The higher the gear the worse it seems to be. From 6000 rpm when I full throttle 6th gear struggles to get past 7000 rpm at all. When the bike is in neutral the revs can be cranked up to high revs. no problem. Work that I have carried out on bike recently, as follows: New aftermarket downpipes, oil filter, oil, spark plugs, spark plug caps, fuel filter, fuel cleaner,air filter, new carb inlet rubbers. Work carried out on bike recently by bike mechanic, as follows: Chain and sprockets, carb's stripped / cleaned and reset. CDI unit changed over. Mechanic said the jets are clean and in mint condition. The latest thing that I have tried is fitting an original set of dwonpipes to see if that would help. It didnt. Any help would be greatly appreciated, this is starting to do my head in. Many Thanks
  5. Thanks for your advice blackhat250, it's my first time every using a forum. How do you post this in the workshop? I'll get the jets reset, do you think the new aftermarket downpipes may have caused this problem?
  6. Hi there, recently bought a fzs 600 fazer 1998. I'm having a problem with 3rd to 6th gear between 6 and 7000 rpm. When I'm in 3rd gear I can slowly excelerate through 6 and 7000 rpm but the bike splutters. The higher the gear the worse it seems to be. 6th gear struggles to get past 7000 rpm at all. Work carried out on bike recently, as follows: New downpipes, oil filter, oil, spark plugs, spark plug caps, fuel filter, fuel cleaner,air filter, new carb inlet rubbers, chain and spockets, carb's stripped / cleaned and reset. Any help would be greatly appreciated, starting to pull my hair out. Many Thanks
