Chalorr
  1. Thanks for the Keiran, had a look at that post, he's got compression and no fuel, mines the other way round, got fuel in the sparks and all the carb/fuel supply is clear but I have no compression in the spark chamber when it's turned over, I think a valve has dropped or the piston rings have gone. It's ok now anyway, my father took it away in the van to drop it off to a fitter he knows so hopefully I'll know the extent by the end of day, I'll let you know.
  2. Hey guys, Bought an '01 XV 125 about 8 months ago, my first bike. It seemed to be in fantastic condition when I bought it (had my father look at it before I bought it who's been biking for 35+ years) but since I started using it everyday, it's had one issue after another. The latest occurred last night on my way home from work. It lost all power then cut out got it home in a van and had a look at the fuel supply, pump and tank. No problems at all there (had the father help, who's always done all his own maintenance) when firing it up now, the rear cylinder fires but the front has no compression what so ever so the front cylinder needs to come apart. This is where the problem is. I cannot find on the net anywhere the workshop manual to follow to do this. Is there a guide ? Or can someone post either the settings or point me to the settings somewhere? I would really appreciate the help, I would rather have find out what part of the cylinder has gone before booking it into the garage and pouring yet more of my very short cash supply into the damned thing!!!
  3. That's a great tip thanks Never another quick question, I figure I might as well drop the oil and put fresh in while I'm at it any suggestions on what oil to use? Thanks
  4. Hey Guys Need to buy a new chain for my bike an '02 XV 125 Virago I think the size I need is a 520/114 but when I'm phoning around my local spares shops they all seem to think it's to big. Is it the right size, or have I been miss-informed? Any help greatly appreciated. Thanks
  5. Hey Guys, I have a 2002 XV 125 Virago, had it about 6 weeks and been using it in all weathers. Decided today to give it a bit of a clean today and think some water has got into the fuses as some of the electrics have gone off (indicators, brake light, neutral/indicator lights on handlebars) but headlight and rear light ok. I don't mind changing the fuses myself,however I don't know where to find them, I have taken the side panels and under right one are 2 boxes, I think they're in one of these. So to the help bit, am I right in thinking one of these 2 boxes act as a fuse box? and if so, how do I access it to check the fuses? Also, as a bit of a side note, does anyone know where I can get a Haynes type manual? Searched everywhere and kind find one. Thanks.
