Seana23
Everything posted by Seana23
  1. Ahha! is that the light i see at the end ov the DT125/175/175 (replacement engine)MX/LC tunnel......... Thanx DirtyDT, i think that diagram is the closest im gona get to fix this sickly Hybrid/Mongrel plugger... Some ov the wires on the bike are different colours to the diagram but i think they actually correspond to whats fitted to the bike (except, i noticed that the LC CDi has 4 wires not 6 but i think that maybe the extra black wires on the MX(?) CDi may just connect to each other (?) I'll have another look tomorrow and report back, if you dont mind me keeping this thread going, as im going for the record!!!. ...........or maybe, just maybe that light i can see is an oncoming train!!! Seana XXX
  2. it is an MX!!! Defo not an LC. i would have noticed the radiator, the hoses, the different engine, the different tank and panels... well, i'd have jus noticed! XXX
  3. Thanx babes. no probs. i got one off my GS that she doesnt need.... XXXX
  4. oil tank on right. engine number 10V-005186 frame number:- obscured by powder coating on frame!!! Wiring anomolies as follows..... on loom AND lighting switchgear Blue/red wires.... but no Blue/Red wires anywhere on diagram!!! wires from Generator/stator plate... :-Green/Yellow. Yellow. White/Red. Brown. Wire from Neutral indicator is Light Blue. 6 wires to (and from) CDi. Orange. Black/White. Black. (one Sub-loom) White/Red. Brown. Black (other sub loom) and most annoyingly... no red wire to attach the bloomin battery to!!!!! Got the Negative wire but no Live (Positive)!!!! any ideas? XXXXXX
  5. Only time i get a chance!!! xxx
  6. no results found in search for magneto grommets....
  7. dont worry, anyone could have made that simple mistake................ ................anyone whos A BLOODY AMATEUR. LOL \o/ bless. ill put the kettle on at about 5ish for ya. xxx xxx
  8. DOH! Bless ya. xxx
  9. no.... no use at all!!!! only jokin. thats EXACTLY what i was after... not just a bit but 100% spot on! Thank you babes. XXXXXX
  10. wheres the RD forum? is it the streetbike section? XXX
  11. Ok, Little update... so it has a square section swing arm so its consequently a Mk2 MX (6wire Cdi, not 7 as stated in georges previous posts) thanx all. XXX
  12. hi again. there only seems to be 5 wires running from the flywheel magneto. ( Yellow. White/red. Brown. Black. Green/white.) and 6 going into the CDi box. Typicaly, the Haynes manual states either 6 wires (extra red) or 3 wires (Green/white. yellow. Black/white and light blue) running frm flywheel magneto... EH??? WTF? other than that the loom seems to fit and everything else seems to be there and working ok. Although i may have worked out why things were not working properly as the frame has been heavily powdercoated, including all the Earth points! think the guy forgot to mask them or blank them off!!! DOH! XXXX
  13. Could anyone tell me the name ov the "Itzzy-bitzzy-teeney-weeney- little-rubber-grommet-thingy" that the wires from the stator/generator go through as they emerge from the engine casing........ Im lookin for a replacement as the one the one on Georges has seen better days (about 20 years ago!!!) thanx all. Seana X X
  14. Hej da all. I'm currently putting lights etc onto a naked DT175MX for George whos a forum lurker here... I have a spanking new loom to play with.... BUT..... The Loom-Lug positioned on the frame top tube indicates to me that the wires run on the left ov the frame, under the tank, to the seat rails but im unsure as to whether it continues on the left, running alongside the exhaust (this seems wrong to me) or whether it crosses over the monoshock onto the right hand side, and then runs along under the seat to the Battery, Stoplight etc. Or whether it comes out from under the tank, over the riders shoulder, down the back etc.........\o/ which one, oh wise ones, which one? (obviously not the last one, im not THAT much ov a bimbo!!!) Thanx all. Seana XXX XXX
  15. THX DTYDT. muchly appreciano. bless. XXX
  16. Ok, so now ive got her, you need to bring the battery charger, any wiring bits, including loose wires and the switchgear off the old bike, the little rectifier off the old frame, under the seat. Oh and ya manual. thanx X
  17. Space has been made next to Janas 535 in the back-livingroom... and my Big Hammer is dusted and ready ....! see ya Friday evenin. X
  18. Bring her over and i'll give her a tickle for you. XXX
  19. thanx babes. it must be an old one then as the thickness is 3.3mm from the back ov the plate to the top ov the friction pad. So it only worn 0.7mm... i think the backing to the friction pad must be around 2.8mm so you dont get much pad on the plates then do you? so maybe the springs got compressed a bit or the bearing on the clutch pushrod... any other possibilities??? XXX
  20. DOH! wrong Forum. can the Moderators move this to the Technical section please. Thank you. XXX
  21. Oh wise ones ov the West, i wonder if anyone could tell me the thickness ov new clutch plates for a TY 175 (Twinshock). im helping a friend who has jus bought it, to get it on the Road/Fleld again and the clutch "felt" (as its not running yet) very "loose" so took the plates out and they look pretty thin (3.3mm) and smell very burnt. Would new plates help or is it maybe the springs? or even the Clutch pushrod bearing (if this model has such a thing, (my old 250 did.)) Thanx all Seana XXX
  22. Seana23 replied to Richie_31's topic in Classics
    Hi babes. Have you checked that the timing plate is moving? Ive been reading up on DT125/175 starting problems and broken/ loose Woodruff keys seem to keep reoccuring... I think you can remove the casing to get to the Rotor and peek behind it at the timing plate to check its not moved. Just a thought. Xxx
  23. Hi again. There seem to be loads ov posts about no spark on DT175's... Quite a few result in people replacing a broken Woodruff Key on the Crankshaft which stops the Timing Plate from spinning round and putting the timing off... Stopping the spark plug from firing at the right time. This would account for the "raggin it up and down the road" bit before it stopped working... Ebay has a DT175 Rotor puller for £10. As this problem seems to happen every now and again it'll be good to have the right tool for the job. Get one and we'll get her up and running again. Seana Xxx
  24. Hi George, ive been researching the potential fixes and they are many and varied... from loose wires, broken CDi's and dead Coils to a snapped Woodruff key!!! bet you didnt even know you had one ov those!!! anyway, i'm sure i can fix it, even if it is the Woodruff key problem as we have a Rotor puller here... Bring it round and we'll have a good look at it for ya. see ya s :spin2: n. Seana X nice to be on such a posh forum...
