YBR125 short mirror stems
As mentioned bar end mirrors or if they ar the old fashioned chrome stalk type cut the stalk in half and then run a die down it ie 8mm then turn up a bar of about 3 inches and thread that internaly at each end or all the way through. Screw the bit you have internally threaded onto the bit from the handlebar then screw the mirror end onto that bit and hey presto you have gained some mirior. Make it decent though and use a bit of stainless it is just as easy to do a job properly than do a bodge joob !
sr125 top speed problem
How fast do you expect it to go then ? You say it could be lean - what does the plug say ? What is standard gearing ? To get something to go faster there are so many variables best thing to do is get it going right as standard first. If you want to p/m me i will help you if I can but get back to standard is the first point to get anywhere.
replace clutch
Are you sure it is the clutch plates to start with ? If so it aint going to cost you a fortune and you can do it yourself in less than a morning. If it is the friction plates buy original if possible as in the long run they are not going to be expensive unless you can find some pattern ones with sureflex linings on. New springs are only going to be in the region of 3 quid or so each so change them if you want to but for the cost involved its a no brainer realy, however if you aint sure check the length against the spec.
XJ6 TYRES
Too much brand snobbery with tyres nowadays. Bit like chav's having to wear certain trainers. If you are happy with the tyres use them. OK so tyres are a real important bit of kit to us lot but you must feel comfortable with the kit you use and tyres are no different. I use Heidenau tyres on my race Triton - I can hear it now at the back of the room what and who are Heidenau ? - Well I can tell you after seasons of using KR 124 and the like I tried these tyres and have never loooked back. They come in sticky compounds even in 18 inch sizes do not cost the earth and are superb in all weathers. I have also started using them on some of my road bikes and still they are superb value and offer predictable usage. If you ever venture over the pond to watch classic racing you will see Heidenau used on all sorts of kit including TZ's who at one time were the place to find KR 124's !! We do not anymore thankfully have the old style Nitto no grip crap from the 70's. But saying that I bought a new TZ and it came with Yokohama's as standard ! but they were a direct copy of the old trigonics in the pattern and profile. We should all share our experiences with tyres with each other but bear in mind we all ride different. We have been ripped off by tyre manufacturers prices for too long now, start looking at the alternatives and share data via the site.
DT 125 LC throttle cable.
Sorted then. Who needs a main dealer ? The old ways are the best !
If the end nipple has got stuck just heat it up with a blow torch and it will dissintegrate itself ! Then measure up what you have left and make your new one.
If its just the inner thats gone as that inner looks to have a nasty bend in it just make one up then you know its the right one. Any probs on bowden cable supply p/m me or get a copy of old bike mart.
What SPARES do you keep in stock?
blackhat250 this has not scratched the surface of what I have realy cos I have no idea myself ! It is spread around a bit due to space but you get the gist of what I think is essential to keep "in stock" Where are you based in Scotland as that is where I am just in case you need something that I may have "in stock" to help out.
Forgot to add chains and sprockets for everything split links including half links. Buy your chain in 5 meter length's cheaper and you allways have spare !!!!
I keep just about everything even for bikes I no longer have ! I try to keep the stuff in boxes marked up with what is in them. So................ Plugs various grades for all bikes - buy them by the boxfull from fleabay Cables for all bikes plus bowden cable, outer cable, nipples and stuff for making my own cables. Oil - lots of it for all bikes and filters. Spokes and wheel rims. Crankcases. pistons and rings. bearings for everything marked up for what they fit eg - 6202 wheel bearing for Triton front wheel spare engines - a good way of keeping track of spare parts taps, dies and hellicoils - all threads imperial, metric and japanese metric thread guages and files bits of brass, tuffnel, dural, phos bronze, delrin, ally for turning up spacers bushes etc footrests light lenses, bulbs and fuses nuts, bolts and washers - all sizes and threads loctite crankcase sealer grease blue hylomar triflon bits of inner tube seat foam dzus fastners split pins lockwire hand grip rubbers footrest rubbers plastic nuts and bolts for fairing screens grp and carbon electrical wire and connectors and shrink wrap Tape - electrical and duct cable ties This is by no means all of what I have in "stock" and does not include tolls, lathe, mill, welding kit ( metal and plastic ) grinders, polishing kit etc etc. It seems to just creep up on you realy but I reckon all the stuff is usefull !
engine change for log book issues
It is a kickstat model so the battery is a real small one. I can fabricate an ally oil tank myself as well as engine plates in dural. The airbox will be ditched for k & n or similar. Changing an engine over in an hour is not rocket science I can and have got my Triton engine changed in under an hour and that was at a meeting not at home in the workshop. Bracing the frame will also be done myself and will be doing some serious working out where to do it. I am not tuning the motor or uprating anything on it and will use the standard pipe set up on the XT and for the 125/600 bike will make an underseat route pipe to finish in a aftermarket silencer. So at worst It is jetting that will need to be changed between the 2 bikes. I do have a spare pair of carbs so that is something that can be left in place on each frame. Cynic if you can remember what bike mag it was in I would be interested in reading it. Probably help me avoid some screw ups !
Had thought of that Nev but I have a supermotard type thing. Its an old CR 500 Honda, last of the aircooled ones but with pro link ( must have been last of one model and first of the next ) I used it for hillclimbing for a few years before getting it sorted for the road. It's a real hoon to ride n makes you want to ride like a hooligan all the time. I even had a bit of tuning work done on the motor as if that was realy needed ! The best thing about it for me though is it's a 2 stroke. It can be a pain to start at times but that soon offsets itself when you ride it.
does anyone know where i can buy yamaha r6 oem fairings
Fowlers of Bristol but make sure your wallet is fully charged lol !
Sounds reasonably straightforward but I am sure there will be some bloody hiccup ! The plan is to put the XT 600 engine in a TZR 125 frame for the summer but put it back in the XT frame for winter. This is I suspect where I will have the problem. All I want to do is have a big single sport bike in the summer and trail in the winter. I know buying another bike is the easy answer but a few reasons not to do that 1. I have enough bikes as it is 2. I like the XT engine in a 125 frame idea 3. I like a challenge and a project. Once sorted an engine and exhaust change from one bike to another is a matter of an hour and I get the best of both worlds. I am unsure of all the model numbers/names for the 125 but want one that is a beam frame so I guess I will be looking for something from the last 8 years or so. If someone knows which sort I am looking for I will be gratefull for the info. I looked at an Aprillia frame which would be ideal but I want to use a Yamaha set up so that is the sort of frame I am looking at - basically a dead engine 125 complete is what I am looking for.
I am planning to put a different engine in another frame. Is this just a straight forward logbook change ? The engine is a different one to the one that was originally used in the frame but it is still a Yamaha engine Yamaha frame configuration. Has anyone had any dealings of this sort of things before ? I know all the dodges to get a Triton registered but have never done this type of thing before so any info would be helpfull. Thanks in advance.
