scobri
  1. The shims on a YZF are located under the camshafts, which means you have to remove the air box,poss carbs & cam cover maybe the radiator to get even more roon to see.The exhaust does not have to be removed,you should`t need to have too much oil either as you only loose about 50cc of oil when cam cover removed.If they have just done some work on the bike & now it leaks oil you will need to go back and ask them to rectify the leak. When you accelerate hard it may be smoking as it is running a little rich. This maybe that there is some wear in the emulsion tubes in the carbs. The carbs are effectively laying on their side & when the slides move up & down the needles may wear the emulsion tubes (Oval) & let in extra fuel. Hope this helps a little,feel free to ask more questions,will help if I can
  2. scobri replied to johnnynhl's topic in Classics
    Try Granby Motors in Ilkeston (0115) 930 0020, you may be surprised at what they have in stock
  3. scobri replied to gogs's topic in Yamaha Workshop
    I can`t say if it`s a definate bolt on but the engine is very similar. If that helps
  4. If your bike is running ok the CDI is working,otherwise substitute for a known working unit. Your bike doesn`t have an EXUP valve on it.
  5. It sounds like your charging system has failed. If I remember right your generator/alternator is located under the carbs. You may find that it is the regulator/rectifier ,which is in the generator unit, that has failed. It may be cheaper to replace with a complete second hand unit but check with your yamaha dealer for parts availability
  6. Yep, 18" rear tyres were the norm until the late 80`s. Bridgestones are good tyres,I used a pair of them until recently on my FZ in the same size as yours until I converted to 17". I got around 3000 miles out of the rear including two wet track sessions at Donington,very good feel. Try M&P, sometimes they have deals that you just can`t leave. I bought a pair of Metzlers for less than trade price.
  7. That would depend on how wide the wheel is,by runnig that size tyre i assume that you are running a wheel off a FZR1000 which is 4.5 inches wide,that would be the ideal size for that wheel.You can fit a 170 if you can get hold of one. If you are running a standard wheel 3.5 in wide that is far too big and would give major stability problems
  8. I`m gonna get real technical with you now,think biscuits. Ideally you will want a colour very similar to a rich tea biscuit that has been dunked in coffee,if you have a colour which is lighter than an undunked rich tea it`s runnig too weak,if you are heading up to a digestive or choccy digestive you are heading up the richer end,then if you have a triple chocolate cookie you are running far too rich,so moral is when carb tuning always put kettle on first grab you nearest box of family choice biccys & away you go.
  9. I have gone down this route with my FZ750,first using a 1000 genny wheel but wanted better choice so went 17". You could use a complete 1000 Exup rear end,not a difficult conversion,I used a rear wheel off a 600 thundercat.It uses the same sprocket mounting so no grief when changing them,you can use you original caliper but will need a different rear disc & caliper mounting bracket.If you buy all thundercat parts you can then adapt in different ways because anything you do will need adapting. If you need more help & I`ll do my best.
  10. You are right,it will be the exup valve causing you a prob.You could try pegging it open & taking it for a ride. Strip your valve out of the exhaust,be prepared for broken bolts though as there are a bit of swine.You will benefit massively from this,reassemble with loads of copper slip,replace both cables as your problem was probably the exup valve seizing up & the other is probably streched as well. Try granby in ilkeston 0115 9300020 they usually have them in stock,knowledgable guys in parts & the workshop manager is a top guy
