yamamastr
  1. ok yeah since it makes no diffrence with the flywheel off what chould it be
  2. ok so i am now at the point where i am uterly confused. i took the flywheel off no diffrence in the way the engine feels. im starting to wonder if theres a bind. but i was able to start it once rode it halp way around my block and then it cut out had to push it home. took plugs out putt it in high gear and it rolls but its tough im letting some two stroke sit in the cylinder to realy lub things up. and when you kick it in gear it lurches fwoward so i dont think i put it together wrong. choul the new seals cause this toughness i didnt oil them when i put them on.
  3. whould putting washers on the crank where the flywheel goes help solve the binding problem?
  4. ok so i found out that the points werent opening and closeing so i adjusted them and whala i got spark. my problem now is that it seems like the flywheel is binding not allowingthe motor to spin correctly chould washering the flywheel help?
  5. two years ago i bought this bike and it was running but the engine was week. i have replace all bottom end bearings gaskets oil seals along with new piston rings. today i have got my bike compleatly reassembled and put back into the bike it has compression and gas but no spark i have tried sanding the points but no luck i cant think of anything eles to try any help whould be apprechiated.
