Sammyt80
  1. Hello, Does any body know how the procedure for regreasing the bevel box on a townmate, what needs greasing and taking off. Thanks Sam.
  2. ive been out nearly every single day, frost, snow, sleet, rain you name i went out in it and the towny just did her job
  3. How was it applying the paint and what preperation needed doing beforehand as would like to do this to the towny, NATO green body, black swing arm
  4. I haven't been on here for a while, But got my newish bike, a Yamaha ttr 250 1994 6000 miles, Needs tax and Mot Got no idiot light not sure if Mot failure Both tyres say motorcross use only deffo mot failure Abit of rust here and there.
  5. Been having abit of an on going problem with the timing chain on the bike, before it wouldn't adjust and making a slapping sound, fitting a new Spring and it approved abit but when adjusting it would go tight then slack again and when riding it quiter but still making a noise.
  6. Sammyt80 replied to Sammyt80's topic in Yamaha Workshop
    Sorted just the inlet valve Tappat cover has rounded and can't access the inlet rocker and valves any suggestions.
  7. Sammyt80 replied to Sammyt80's topic in Yamaha Workshop
    13 presses against 8 there a notch in 8 which acts as an a locking type thingy, I will stretch the spring to give more adjustment.
  8. Sammyt80 replied to Sammyt80's topic in Yamaha Workshop
    I will have a look tomorrow, just going to change the screw it could of worn down and not hold the adjuster in place and stretch the spring and also valve clearance, just got the proper tool kit through with every thing needed to do that including feeler gauge and rocker adjuster holder, really hand little tool kit. I could be talking rubbish as well but see what happens tomorrow
  9. Sammyt80 replied to Sammyt80's topic in Yamaha Workshop
    Got a new adjuster screw and going to stretch the spring abit and see if that helps tomorrow, It's semi auto adjusting meaning I have remove part number 13 and turn the engine over twice then replace the screw and the spring takes the slack up.
  10. Sammyt80 posted a topic in Yamaha Workshop
    My t80 has got a ratterly cam chain I adjusted and then 2 days later it's slack again the engines only 12,400 miles and don't think it needs changing. Some body told the adjuster screw could need replacing and then give the adjuster spring a slight stretch to sort, does this sound right
  11. Sammyt80 posted a topic in The Bar
    does any body know if the Yosimura exhaust for the honda c90 will fit a yamaha townmate, i think the cubs down pipe is 32mm.
  12. Sammyt80 posted a topic in The Bar
    Is it possibly to fit an oiler cooler to my t80, seen them on cubs and fancy one, what would involve in fitting them. http://www.pitbikeparts.co.uk/cooler-used-engines-p-723.html
  13. so should it take around 1hour to do, i have to ask other places to see how much they are.
  14. Hello, Noticed my bikes gets a bit of top end rattle when hot and think the valves need adjusting just been quoted £70 and says it takes 2 hours to do, just wondering how easy it is to do my self and whats involved in doing it.
  15. Sammyt80 replied to fieldarcher's topic in The Bar
    my t80 is called Elle after having elephant grey paintwork
