Everything posted by rdbug70
82 XT125 cutting out over 1/2 throttle
Main jet was clean and clear. Turned out to be one half of the stator assembly was bad, had evidence of melting the epoxy coating of the windings. Replaced with a used one , runs great now.
Just to please everyone I will pull the carb for the fourth time and check it out again. Again I will remove the main jet and run a torch tip cleaner through it as I have done before. I will try to take pictures to show also. OK lol I even have a filter in-line before the carb. This is why I wondered if it could be an electrical issue.
I know the jets are all clear and clean. Removed them and used a good carb cleaner along with compressed air to make sure all passages where clear. Does kinda make sense about the battery.
I became the new owner of a 1982 XT125 that is in great shape. But it cut's out when ever you go past 1/2 throttle. Runs awsome other-wise. Have pulled carb an cleaned, idles fine, checked fuel tank , lines , filters, all flow fine. Acts like lacking gas , but I know thats not the case. I do have an issue with the lights though. If I turn on the signal lights with the brake on , the signals won't work right and the tail-light dims. I have tried by-passing the little green thing bolted to the frame neck on the right side with a red & white wire and lights work fine then. Don't know what that part is nor can I find it to buy. Also does it need to have a battery to function properly ? I just can't afford to spend much on it replacing parts that I don't need to. Any help would be greatly appreciated.
New/old Yamaha owner
New owner of a 1982 XT125 an looking for help. Will post in tech/help section.
