dpreece
Everything posted by dpreece
  1. Hi I got a dt 125 that's looking abit old mostly rust on the frame and swing arm I'm not that wise to bike at the more and I was woundering can I spray the frame with out taking the engine out and all out?? And with the swing arm how do you go about removing it??
  2. Yep my oil cap is a milky colour so it's a new head gasket and a water pump seal I need cheers
  3. I've tryd looking for a rubber gasket but I can't seem to find one. I also spoke to my local garage and they reckon it might be my water pump seal gone because of the oily water in my rad does that make any sense to you??
  4. I got it off eBay the 1 gasket was like cardboard and the other 1 was metal. Any ideas wer to get a rubber 1 from because I'm just might strip it Down again
  5. it was a metal one.
  6. hi can any one help me ive got a dt 125 i had gunk in my rad so i changed the head gasket and everything was fine. now after a week or so i have to keep topping up the water up and i got gunk in the rad again. and i havent got a clue why this is happening
  7. ive got gunk in my rad so i changed the head gasket because i fort that was the problem and after running the bike for a couple of days the gunk is back in the rad can anyone spread some light on this for me
  8. thank you very much for your help i done what you said and the bike is running mint now i cant thank you enough thanks again
  9. thank you very much for your help i done what you said and the bike is running mint now i cant thank you enough thanks again
  10. can any one help me please i changed the head gasket on my dt 125 the other day and took the power valve off the head when i finished i put it all back together by putting the head on then i put the power valve back on then i started the bike up and it was running fine so i took the bike out for a run and i new there was something wrong with my bike then power valve was not kicking in now the bike will only do about 50mph and it wont rev over 7000 revs. can any one help me pleaseee
  11. i changed the head gasket on my dt 125 the other day and when i put it all back together and put the servo back on i took the bike out for a run and now the power valve wont kick in the bike feels like its been restricted it wont go no more then 50mph can any one spread some light on this for me pleaseeeeeeeeeee
