whillis
  1. Hi, I have a 98 thundercat, and its been great untill now. For some reason it is getting hard to start it. I turn off the alarm, turn on the ignition the fuel pump clicks a couple of time, then press the starter button. It will turn over for age's then fires one 1 then 2 then 3 then 4 and its away, but this can take several attempts. It used to start without a problem, I have just had the carbs balanced to see if it would help but no good. Should the fuel pump click or should it buzz, it has always clicked even when it was starting ok. Hope you guys got some good idea's Kind regards whillis
  2. Hi Guys, Im just about to service my 1998 thundercat ready for the summer, if it ever come's. Im after some general help, im going to change the plugs, air filter, oil filter, oil, but how much oil should it take?, and the other thing is how much slack should be on the chain? The cat is running fine apart from one thing, it seems to hunt a little on idle is this normal? Hope their is some help out there, kind regards whillis
