Steve_05GT
Everything posted by Steve_05GT
  1. Ive fixed the YQ100 Aerox common non starting issue!!! It turned out that the engine had compression but not enough to start the engine basically the upper piston ring had twisted and scored the barrel. This was due to a heat problem which is really common on the Aerox bikes, The 100cc are air cooled which is really daft... For anyone else who is stuck I basically ordered from ebay and replaced the following... New Barrel New Piston & Pin New Piston Rings New Reed Valve New Spark Plug Now she runs like a dream and got it back on the road for less than £120 hopefully get a few more years out of the old girl!!
  2. Welcome mate...
  3. Any more thoughts I'm really stuck...
  4. Hi mate well the engine is attempting to start you can hear the compression so to speak What colour is the spark? -- BLUE Does the spark get damp with fuel? -- DOESNT SEEM TO BE THAT DAMP BUT YOU CAN SMELL THE FUEL VAPOURS ON THE PLUG IF THAT HELPS Does the engine turn over when you try to start it -- YES STARTER MOTOR IS TRYING TO CATCH AND PISTON IS MOVING FREELY Will it push start -- DO YOU MEAN BUMP START? IF SO I HAVENT TRIED.. Have you tried easystart -- YES Are you happy the carb has been put back together and fitted correctly -- YES THE JETS IN THE FILTER BOWL SEEMED OK Same as above with the reed valve. -- YES
  5. Hi guys My name is Steve and im from Bristol. Ive currently got my eye on a R6 but at the moment we have a Honda CBR600RR and a Yamaha YQ100. Ive posted a query in the workshop section as im having a bit of a problem with it... Chat soon peoples... Steveo
  6. Hi guys and gals Im having a issue with one of our bikes and i need your help. Basically im having a huge issue getting our 52 plate Aerox YQ100 to start I will list the following which has beeen done and if anyone can help i would be hugely grateful.... Air filter replaced. Brake light switch is operating as is the cables. Breather pipes are clean. Carb has been dismantled cleaned and reassembeled. Engine has compression and piston is moving freely. Fuel tank has been drained and replaced with new fuel. Reed valve block has been replaced. (old metals petals were warped) Spark plug has been replaced and is producing a spark. Starter relay clicks. Starter switch seems to operate fine. All the above has been done but the thing will still not start! Could it be a CDI unit as ive heard they are common to fail on Yamahas?????
