Ormer
  1. hi looking for a bit more knowledge i believe my problem to be the starter clutch on my bike any advice is this a job for the novice problem is press starter and you just here what would sound like a fast whine from the starter motor press starter and occasionally you here it grip and attempt the start the bike then slip and carry on whinnning any extra incoime would be appreciated this is on a xj750 1986 shaft drive imported from aiustralia as an ex policebike Many Thanks
  2. hi this may be a strange or simple question i am looking at changing my jets on the above bike as i think i may have the common problem of ovaling emulsion tubes how do i know what size are in at the moment with out having to take them out to replace them Many thanks In advance a bit of a novice on a bike
  3. Ormer posted a topic in The Bar
    hi i just got an exhaust from ebay and it is stamped 4hn and i didnt know there was a difference and my bike is a 4hd am i going to run into any more problems or does any body know any other diffrences that i may run acrossin trying to put the bike back to original parts Many thanks in advance Ormer
  4. i just got my quote and i was thinking same as you and my insurance said that if it was not garaged beteween the hours of 9pm till 6am while home it would be classed as an uninsured bike if anything was to happen to the bike as it was insured to be stored in the garage
  5. Ormer posted a topic in The Bar
    hi folks ok a bit more from you lot hi i have a yzf 750 that has a johnson end can on it and have spent time looking for information on it but cant find anything so wonder if any one out there can assist on any information PLEASE many thanks in advance
  6. Ormer replied to Ormer's topic in Yamaha Workshop
    YES I WAS GETTING A BIT FRUSTRATED WITH IT no never needed choke yet to start also told today that a chance that it could be running to rich as it not needing choke and that it is a bit wet on exhaust
  7. no that be Guernsey in the channel islands
  8. Ormer replied to Ormer's topic in Yamaha Workshop
    bump
  9. Ormer posted a topic in Yamaha Workshop
    Hi as i say i am new here andlooking after advice i have 1995 yzf 750r that has a flat spot between 3 and 4.500 rpm i am just looking for some advice on possible fixes before i spend money on going to garage it is pretty much standard bike but has an end can that nobody seems to know anything about it is a johnson that is carbon fibre looking any information on exhaust or flat spot would be great thanks in advance
  10. Good day every one i am ormer i have just found the website hoping to use to my advantage as i just have bought a yzf 750r 1995 and going look at bring it back to a nice running bike so just wanted say hi and a small introduction i am from near the uk and looking for advice
