Bridgie
  1. Greetings all. I have an XVS1100 [99] here in the UK, I have had to put a new engine in as the old one died. The next problem I find is that when indicators are on the odometer and the N light blinks. Plus when the ignition is on, the starter cut off switch/fuel pump relay (In the head stock area) buzzes clicks and whines and I have replaced it 3 times. The fuel pump did fuse and short itself out last month and it has been replaced, the fuses are all intact The new pump is good and runs happily from a battery but plugged into the harness it doesnt get any voltage or current when the ignitions on. The battery is sound and cranks the engine over. Have I stuffed my CDI do you think? Thanks in advance for your help.
