Barking Mad
  1. Better all done! http://www.barkingmadspeedshop.com/2011/07/shes-all-good-to-go.html
  2. In the final stretch! http://www.barkingmadspeedshop.com/2011/07/down-to-final-bits.html
  3. Carb is on! http://www.barkingmadspeedshop.com/2011/07/carb-is-done.html
  4. Triples and speedo mounted! http://www.barkingmadspeedshop.com/2011/07/triples-spedo-and-headlight-mounted.html
  5. Today... Rear wheel is laced up and ready to be trued Rear sets are bolted up Wiring is being put on and lengthened where needed One side cover is polished All of the shift assembly and brake assembly have been cleaned and polished up Picked up the tank Polished spoke nipples Painted some stuff Picked up a bunch of parts, heat shrink, connectors, replacement brake switches, another bunch of nuts and bolts and some other odds and ends...
  6. Motor is in! http://www.barkingmadspeedshop.com/2011/07/motor-is-in.html
  7. it looks good lots of work tho, Almost should have painted them just almost tho...
  8. A few updates things will go quickly now.. http://www.barkingmadspeedshop.com/2011/07/its-alive-or-at-least-roller.html http://www.barkingmadspeedshop.com/2011/07/hubs-are-about-done.html
  9. Few updates! http://www.barkingmadspeedshop.com/2011/06/tank-is-stripped.html http://www.barkingmadspeedshop.com/2011/06/built-or-better-said-split-chopped.html http://www.barkingmadspeedshop.com/2011/06/first-batch-back-from-painters-and.html
  10. Soda blasted the motor today.. http://www.barkingmadspeedshop.com/2011/06/soda-blsating-motor-stage-1.html
  11. The hammer stopped the seat from flopping off backwards. I expect it will be a fun little bike. we toyed with a larger motor but was not sure the frame would take it. The frame has had all of the tabs etc removed, I weighed the frame and its 19 pounds the stock one that I have with all tabs still on is 27 pounds.
  12. Barking Mad posted a topic in Projects
    Just building an SR250 Cafe here are some pics http://www.barkingmadspeedshop.com/2011/02/1980-sr-250-cafe-bike_21.html Just moving to the exhaust any ideas?
  13. New to the site, lots of good info just building a sr250 cafe
