gemini
  1. red hot water, goes on easy and doesnt move once its cooled
  2. Even when warmed up the air screw has no effect when turning in (even closed) . this is due to the pilot jet size, float height wont affect it, but main jet size does slightly, better to start of with the standard jets and go from there
  3. shame you didnt reply to none of my pm's, i was going to bring you a carb to try as its nothing to do with the electrics
  4. good link, thanks
  5. gemini replied to splittie65's topic in Classics
    just take the cover off and have a look, the electric start 125 does have one, yours may not
  6. gemini replied to splittie65's topic in Classics
    easiest way is to take the head off and use a feeler gauge and a straight edge, this is the only way to get an accurate reading as the piston is domed on top and the plug is on one side, the advance should be held open when you set the points, a cotter pin spread apart works well to hold it open
  7. not sure if Cynic forgot the link but its here http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php
  8. http://www.yamahamotorcyclespares.co.uk/spares/partImage.asp?GPN=Z%3AO%5D68%3A%3D%3B5555&uid=0
  9. the bike will start while on the stand, it will cut out if you put it in gear while the stand is down
  10. mixture screw is here, there should be a black rubber bung covering it
  11. did you do a compression check on both cylinders before you stripped it
  12. have a look here http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?ModelID=9738&pageID=3&m=YAMAHA+XVS125+2002+CRANKSHAFT%2E+PISTON&uid=0
  13. you will need a 17.5 pilot jet, the standard one is a 15
  14. could be just overtight
  15. slick 50 was made for worn engines
