happymaxim
  1. I removed the rear wheel to replace the tire. After reinstalling the wheel the clutch will not disengage. When i pull on the lever, every thing moves back an fourth. It did seem looser then before the tire change. I tighten the slack nuts on the lever but still no change. With engine off, I can put it in gear and back to neutral with the foot clutch petal. when the engine is on, it catches an stalls out when i put it in first gear. It has a drive shaft. Could i have hit some thing or not put it back together right? Im stumped, i thought they were two different things.
