chrissy w
Everything posted by chrissy w
  1. hello, i read the other day that somebody had changed their valve from 66 to 116, what does this do and where can i buy one from? thanks chris
  2. hello I was woundering how to derestrict a yamaha tzr50 and the parts i will need to increase the performace, where are the restrictors? how much will it cost me? thanks chris
  3. thanks, ill ring them on monday
  4. Hello people, i have got a yamaha tzr50 2004, and the brackets for the fairings are missing, i was woundering if anyone knows where to get them from as i have searched the internet all over and cannot find any
  5. i bought this off ebay for £2.00 http://uk.farnell.com/allegro-microsystems/a1220eua-t/ic-hall-effect-latch-sip-3/dp/1698206?Ntt=A1220EUA I had to take apart the speedo assembly on the front wheel, then i had to crack open the sensor with a screwdriver, you then have to unsolder the black resistor and put the new one on, after doing so you then have to glue the plastic/ rubber seal back together then put back onto the bike. With a bit of look the speedo should then work
  6. thank you so much! iv fixed it!
  7. howw would i go about fixing this?
  8. yeah its all one wiring block but the wire splits off to the front wheel.
  9. its a wiring connector, im only 15 so im not as experienced as most people on here, but the there is a big block of wiring on a clip that goes on the under the speedo.
  10. yes mate iv checked the wiring and everythings fine, its got me completely stuck!
  11. I have bought a yamaha tzr 50 2004 plate, the speedo is stuck at zero! i have took it apart in the front wheel and cleaned it out then greased it back up but still no luck, im completly stuck. I would really appreciate some help, thanks
