bry21658
Everything posted by bry21658
  1. if its' a philips screw and everthing behind it is screwed into is solid then i would put som e wd40 on and put the screwdriver onto the screw ,hit the s/driver with a hammer gently first ,then try to undo if no luck repeat but using more hammer force each time providing, everything around the screw is solid enough to take the hammer impact
  2. try turn it with aelectric dril to see if the speedo works
  3. first leave the cable connected to the clock and turn the other end of it to seeif the speedo arm moves ,if it does not then it could be the speedo clock if it moves ok then go to the wheel where the cable goes into the botom piece if youhave greesed it and there is no cable broken off inside you will have to remove it from the wheel and check it for wear ,when you grt it off the wheel insert the end of the cable and try to manuely turn it to tomake sure itsnot stikin ,if it is then you may need to get another piece to go back onto yhe wheel end.iethr way its faulty at the top or bottom.
  4. bry21658 replied to beeky's topic in Naked
    take alook at my posts my be of help to you.bryan
  5. try this,it's an american site iv'e just had sent over its called ,www.speed and sport inc . any probs email me
  6. bry21658 replied to fuff66uk's topic in The Bar
    cook your chips in lard then when its had its use rub your chrome over for winter
  7. try a site called www.zapmeter.com or
  8. try these sites called www.tradebit.com there's also one called www.clymer.com
  9. try these,www.yamahaesponia.com ,www.fowlersbristol.com ,www.bike bandit.com ,www.wemoto.com ,www.yamaha motorspares.co.uk ,these are from u/states,ronniesmailorder.com ,www.worldofpowersports.com ,yamaha genuine parts its a cycle shop in canada www.kellyscyclecentre.com tel no is,001-877-4140404 ,www.speed and sport inc. you will have to googl them them off the web. any problems ,my no is tel,07541393653
  10. try this web site they might be able to help you its called ;I LOVE MOTOR CO.LTD ,THEY ARE BASED IN JAPAN THE MANS NAME IS; MR TOSHIAKA SHIOZU ,YOU WILL HAVE TO LOG ONTO A WEB SITE CALLED ALIBABA.COM THEN LOG THE COMPANY AND HIS NAME TO FIND IT.
  11. wanted is a fj1200 engine ,also does any one know the bbest places to get transmision gears and ratio gears from,anyone who has carb diaphram problems try [email protected]
