mcbrien
Everything posted by mcbrien
  1. Not really , The fork diameter and spacing is right . The center stem is off so Radian top triple will not fit on SRX stem . The SRX stem is about an inch longer and completely different on top so I can't swap stems so the only option is to cut and lengthen Radian stem to fit SRX . I may try this since I work in a machine shop but I'm going to look into other options also. For now I'm putting it back together and enjoying the summer .
  2. Well I bought an entire triple tree assembly with risers off ebay for $40 bucks . So will see .
  3. Well I got you to look I figure I will need a lot of views to get an answer to my question .
  4. I am trying to find out if a Radian (86) top triple tree or the upper & lower as a unit will bolt up to an 86 SRX. If so will it retain same spacing for my front wheel? As you can probably figure out I want to install a standard handle bar and I don't want to drill holes in my stock triple tree to mount risers. Radian triple trees are available on ebay right now at reasonable prices. Unless someone on here has a Radian top triple they want to sell. Thanks,
  5. Hi
    mcbrien posted a topic in New Members Welcome Area
    Just joining in hopeing to find some anwsers to some modding questions. I've owned my 86 srx since 1986. Origional owner , 50000 miles . Yea its my toy now . Any way , will a 86 radian top triple tree fit on a srx ? Thanks
