Daniel mcstanton
  1. hi i have a rxs and im after a micron or allspeed for it micron allspeed
  2. hi im feelin a ride out with 2 strokes /rxs anyone on any or any owners clubs cheers
  3. Hi I have been told that there dt > tzr carb give more power out of a rxs if ya fit one I have put one on my bike and can't get the jet size right iv try the standard jet for these carb with is a 180 and its spluters at top end though ever gear iv taken the front off the air box nd tryed a 160 nd its boggy when ya open the throtle nd revs to 11000 in first then only revs to 9000 rpm in 2en 3ed 4th nd 5th iv tryed a 190 nd feels like its on a limiter at 8500 rpm though. Every gear but feel like it wonts to pull but can't I try rpm nd a 190 and it does the same but at 8000 rpm , iv played with the neadle as well with every jet iv put it but now iv got the 180 jet in the the neadle all the way down nd its better that every jet iv tryed but splutters a bit up to end do I need try a 170 or what cheers dan Need advice
  4. sound need one asap il come pick it up too let me no asap text me if thay have got one mines blue but i work at a body shop so a red one dosnt matter really 07861749403 cheers
  5. blue but not fussy mate wb
  6. hi i am after a rxs 100 fuel tank if you have one please ball me on 07861749403 need one asap cheers dan
  7. hi i am after a rxs 100 fuel tank if you can help me can u give me a call on 07861749403 dan need one asap cheers
  8. my new rxs 100
  9. It start first kick every time could the be the case tho
  10. Ok cheers il cheak that
  11. Done that still running chit Removed the barrel and cheaked the rings nd piston nd barrel that's all fine Replaced the spark plug Replaced the air filter Tried lowering the needle in the carb but even when I put the needle all the way down it still wetting the plug up When it's idle it at about 1500 but keeps rising to 2100 then comes down ect. ....... I don't under stand any of it
  12. Cheaked that same but it's got a 120 main jet in it is this what it serposed to have in . When I pulled the front off the air box then it reved up no problem . Iv replaced the air filter with a thin bit of foam but it's still the same
  13. Hi I'm new to this forum I have a Rxs 100 when I first start it up it revs right over if I leave it running for about 5 mins then I get on it I rev it nd I revs to 6000 rpm then splutters all the way over to 9000rpm then iv turned the oil pump down but since iv turn it down it ain't soon it as bad but it's still there Its doin 70 miles on a full tank £10 spark plugs sandy brown the needle in the carb is all the way down aka clip is at the top it's had a new plug don't seen what the problem is any one got an idea :/
