NE0
YOC Member
Everything posted by NE0
  1. Ditto!!.. otherwise .................................it's frying tonight!!! (and for those thinking outside the box...NO.......it doesn't charge them up!!!)
  2. It also goes without saying, that if you do weld it, don't forget to remove the fuel tank and store it well away from the welder, as molten metal/sparks and petrol fumes have a unhappy relationship!! if you are successful in the stud removal then putting in new studs with a bit of "Copperease" may well stop then seizing again. having said that sometimes it can be so successful that they unscrew and fall out! if however, drilling the studs out is the end result then you can 'helicoil' the holes (threaded inserts) and put in new studs. i did that to my DT head. Where abouts are you? you may find someone willing to help.
  3. Thanks Cynic, yes Airhead also mentioned earlier in the thread and i do like to remind people...this is what i did to my machine! it's aimed at the MX models, it might not always be possible to do it on other bikes.
  4. Hi akleimer, please remember this is a mod for the later DT 175 MX model. Not the earlier ones. it may be there isn't a regulator fitted? Mine was fitted under the airbox, I've known them to fall off. its only one screw and a wire which holds it there! Nonetheless, having said that the wire which goes to the regulator is from the ignition switch, the feed comes up from the generator/magneto. Remember also the c90 regulator/rectifier is a combined unit and replaces BOTH of the disconnected Regulator and Rectifier mentioned in the text. One wire from the regulator and two wires for the rectifier are required. I doubt you can connect the 3 pins to the same source! Have a look at the circuit diagrams for the MX if it helps, but getting a look at the circuit diagram for your bike is a must, the Haynes manual is a good place to start, as it shows US and UK bikes. PS it's also good practice to pop over to the NEW MEMBERS area of the forum and introduce yourself, tell us where and who you are and what bike you have etc,
  5. A little bit of ebay searching and google searching brought up this..... https://www.ebay.com/itm/Yamaha-OBDII-OBD2-MT-09-MT09-XSR-900-FJR1300-MT10-MT10SP-R6-MT07-XSR700/142784680925?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44040%26meid%3Defec2d612d944c6e9e91d1f12b6160a5%26pid%3D100623%26rk%3D2%26rkt%3D4%26sd%3D252780397410%26itm%3D142784680925&_trksid=p2047675.c100623.m-1 But it does also mention a 3 pin and 4 pin connector depending on year. This cable ONLY provides the ODB2 connector socket nothing more! You do of course still need to have a some form of scanner/laptop and an interface tool as mentioned by Cynic.
  6. I've had a look on Google, and found the owners manual (which you probably have) pages 3~11 detail the dashboard but there's no mention of a reset procedure. If its anything like a car, the system has an ODBC connector and the error is stored in memory requiring it to be plugged in to clear and reset the memory. I also found this on a website for the same error but on a FJ-09 and the reply was and seems to confirm it..... the above from https://fj-09.org/thread/5723/2017-reset-check-engine-light So in a nutshell, no i don't think there is a 'user' way to reset it.
  7. errr you could try Google. I found one within 5 secs of simply putting in "virago 535 manual"
  8. NE0 replied to Cynic's topic in The Bar
    Your bikes are not good on fuel Cynic? Then be grateful you don't drive a Stolly to work!! (Alvis Stalwarts. It's another of my Interests!!! ...I love em!!) All petrol driven, Rolls Royce 8 cylinder B engine .They only do about 3 to 5 MPG, and if you filled the 100 gallon fuel tank up (450L) will cost you over £550 to do it.! and it will last you up to 500 miles. So at your weekly rate of 150miles you'd have to fill her up every 3 and half weeks!
  9. NE0 replied to Cynic's topic in The Bar
    (Up until recently) I used the DT on a 15 mile round trip to work. I used it or 3 days one week then 4 days following week. (105m every 2 weeks just for work) plus a bit of pottering in between. I'd get 105~110miles per tank and it cost about £8 to fill up the DT tank every 2 weeks. Get your DT out instead Cynic....? (DT175 has a 7 litre tank for those not familar with this little 2 stroke)
  10. NE0 replied to NE0's topic in General
    ahhh there he is. Ding Dong...................................(rings a bell)
  11. NE0 replied to NE0's topic in General
    Thanks chaps, nice to see the core group still going strong too, I see Cynic is also around . One quick post and it seems like I've not been away! ......actually yes it does!....I accept its been a couple of years!....trouble is, I belong to so many forums I had to curtail my activity as I wasn't getting anything done! So it's not just you folks that haven't seen me either.!
  12. NE0 posted a topic in General
    Hi Guys, yes its me! I know I haven't been around for a while, well years actually!!!! but you'll be pleased to know I'm still alive and kicking.....and so is the DT. I've just posted an update to the DT175MX 12v Conversion following a prompt from Alex and i thought it best to do a little post at the same time. The DT has been reliable and relativley trouble free and by that very nature there's been nothing to report on save for a big end failure a few years ago. However, a quick rebore and new piston saw the bike back up and running within a couple of weeks and back on the road getting me to and fro from work on a near daily basis. I've put just over 2000 miles per annum on the clock year on year and everythings been good. The 12v conversion has equally been doing its job without any problems and to be fair I've forgotton about it, it just works. Wheras the DT has certainly being clocking up the miles, my 400/4 hasn't! Over the same length of time Its probably only done about 200 miles, only coming out on fine days and when I can be bothered to move everything to get it out the shed! On the plus side the 400/4 is now tax and MOT free so I should make use of it more, especially now I've retired! Yup, last year I decided after 40 years of work it was time to hang up my uniform and retire, i know it seems I've now got all the time in the world but I now find there's so much to do, which I've neglected over the years............I dont know where I'm going to find the time to do it all, doesn't appear to be enough hours in a day to do everything! On top of that my wifes decided its time to move, and I'm having to do the house up to sell it, the house looks a bit tired so I'm having to decorate it all to get it presentable, well you wouldn't sell your car without making sure it all works and is all washed and polished to show it off at its best, would you? I feel the same goes for selling your house, got to smarten it up to get the best price. So it's all hands to the pump to achieve it, its not as if I havent got the time to do it!......oh wait ..........I haven't!! (You'll notice I didnt say 'sell your motorbike" in the above text, I mean ........why would anyone want to to that?!........you just can't sell them after all those years together!!! ) So there you go folks, a quick update. I'll try and make more than a guest appearence in the future! all the best NE0.
  13. Hi Guys, i know I haven't been around for a while but you'll be pleased to know I'm still around and so is the DT. The 12v conversion is still going strong and has remained trouble free and reliable, and because of that , technically there's nothing to report. A few months ago I retired and subsequently the DT is no longer being used as a daily commuting bike (which was the reason for getting it) It's currently SORN only because the MOT centre closed down and I've yet to sort it out, just got so many other things on at the moment! (Having said that I'll end there as I don't want this thread to go off topic as it seems to remain a popular post to read.)
  14. Did you get your TV sorted? if not try a factory reset... From the TV Menu, choose OPTION -> Factory Reset -> Yes (wait for a few seconds for the TV to download again) -> OSD "WELCOME" appears -> Press OK button -> Choose Language -> Choose Home -> Select your Country and Time Zone -> Press OK button. might be worth a go!
  15. Thrashed = ridden hard (as above) comes from whipped, thrashing, whipping (always wondered how to use that emoticon!!) wheras Trashed is an Americanism for rubbish....ie, Trash, garbage, to destroy! Now where can you use the emoticon boink gif????
  16. A Ratchet drive and a set of extensions and adaptor bars One of those magnetisers/demagnetizer tools is very useful. Especially when it comes to putting it all back together, screwdrivers, allen keys and even small spanners can go through and will hold the screws in place as you put them back where they came from. A good bright torch/light, because when you need to work on the bike you can guarantee it won't be daylight!!
  17. Darn Sarf Mind you I can't go any further Sarf............. EVERYWHERE is Uop Norf from here!!
  18. and bippo...... if you end up ALL the way Down South you can always stop off and have a cuppa down here in Brighton no Snow !
  19. NE0 replied to NE0's topic in The Bar
    I thought that was a main advantage to Upyours, but i also thought that paying for relay meant I'd get home instead of chaining my bike up and calling my wife to get out of bed at gone 1 am in the morning, didn't get home till 1.45 am. Alarm went off at 6am to get back up!! I feel like SH*t now!
  20. NE0 replied to NE0's topic in The Bar
    I see no advantage in staying with the AA, so I think I'll give someone else a go at renewal in Aug next year. If I cancel now they keep the money.!
  21. NE0 replied to NE0's topic in The Bar
    Got the bike back home, friend shoved it in the back of his Transit, (still wouldn't start when I went back to it) Took it apart at home , rainwater in the carb float chamber was the cause of all the problems. Last night it was raining so hard and the wind was really blowing, unfortunatley the rain cover got partly blown off exposing the engine and carb, a good deal of soaking later and she refused to start thereafter. I can only assume the water got in via the the throttle slide top and down the needle into the float chamber. Once it was cleaned and dried out it started 2nd kick, just like it did yesterday morning when I went to work.
  22. Ever had to use breakdown relay? if so who have you used and were they successful? Had a chance myself to find out when my bike would not start in that heavy rain last night..........and I ended up getting myself home at 1.30 am................ Don't worry I've been on the phone this morning!!!!!! I'm with the AA and have breakdown with Relay, except they used a 3rd party company, who had no means to take the bike home .......or me!....and now I have to go back to work (where I left it) and get her home. They've offered to come out again but I'm so F********* off, I don't want anything more to do with them today. Probably hasty words but when you've only had a few hours sleep thats what happens!!!! RANT over! Does anyone recommend an alternative that will get you home? or is the reality of it:- its fine for car breakdowns but not really for bikes even though its included!
  23. Mines with CIA insurance. £149 full comp fixed price multibike policy for both the 1978 DT175MX and My CB400/4 Thats £75 per bike which to me is perfectly acceptable.
  24. Yup, you can't pull the wool over my eyes..I've also noticed in the first photos the swinging arm has been attached to the wrong end!
  25. and more Lol.....you forgot to take the after photo of the rear brake arm
