Winch!!!
  1. Hi all I have a DT125 year 2005 which has been giving me problems with starting? Turn on the ignition key all lights etc working but starter button dead,with a bit of investigating (reading the haynes manual)I found that if I unbolt the stand switch and tie it to the frame it starts? I have tested the switch with a metre and cleaned the wiring connections and it seams fine also tested the clutch switch and swapped the relays etc, Can anyone help? Thanks Kevin
  2. Hi all I have a Dt125 which has been giving me problems with starting? with a bit of investigating I found that if I unbolt the stand switch an tie it to the frame it starts? I have tested the switch with a meter and it seems fine also tested the clutch switch and swapped the relays etc can anyone help? thanks Kevin
