farley8
  1. hi guys new member here needs some help, my other half has a little SR 125 custom, got it running sweet enough, the problem i am having is that the clutch appears to be jammed!! symptoms are pull clutch lever in it stays in and won't let you engage a gear i have stripped out the clutch and cleaned it all up, the lever etc is working fine, however, the only way i can get the clutch back out is if i move the 'clutch arm on top of the engine back manually however, same thing happens again when i pull the lever in HELP PLEASE (i need to get it sold so i can pursue one of my dream bikes a YZF750!!)
