Ablett88
  1. Yes it has plenty, it has been running but now it just wont go
  2. I have tried new spark plugs Yes it does turn over
  3. Thanks for the haeds up, yea its all flowing through, also put some fuel in the top to try get it started for a few seconds to see if it wasnt flowing through to see if that was the problem but it still doesnt want budge, i have ran out of ideas :/
  4. Was that a sarcastic comment ?
  5. Hi guys/girls, im new to this forum but i have been browsing over the past few days when my bike when wrong a few weeks ago and it seem i could get some advise from you all, i will give as much information as i can and it would be great to get some feed back. So my brother used to own the bike and the piston blew so i got a rebore, new piston and rings and gaskets, put it all together and it started fine, but the powervalve wouldnt kick in, so i toyed around with the servo and looked up in the haynes manual if everything was working fine, to which it was. I then took off the tail pipe and tried to run it, it ran perfect, powervalve kicking in and everything, so i thought it must be the tail pipe blocked of some sort, so i took my mates tail pipe from his DT, Same model etc etc, it started took it around the corner and all power lost. Since that the bike will not kick over and i am cluless to why, oil is going through fine, spark is coming from the plug everything seems to be in order i just can not figure out what is going wrong, after several days of this i just wish i could give up but i cant, i would appreciate some advise on what i can check to see if i can get this running. PS: Sorry for the wall of text, if any of it doesnt make sence to you just come back with a reply and i will try to explain it in more detial. Thanks. Leigh.
