Nooj
  1. When it's running on the stand, is it in gear? If so I reckon it could be your output shaft bearing complaining because the chain it too tight, check the chain tension first and see what that's like. If your dealer PDI'd it or serviced it in a hurry it my have been over tightened, this has happened to my FZS600 and my Missus' FZ6 Fazer, both by the same official Yam dealer.
  2. Nooj replied to Diver58's topic in Naked
    Blimey! That sounds very fishy, glad you all got it sorted! Normally any adverse vibes and balance issues are down to either the bearings being worn, the tyre not being balanced right in the first place, internal ribbing in the tyre's structure (usually on 45 or less profile sportscar tyres), the sealant being way too old to be used (Puncturesafe has a six year shelf life), or most commonly, the wrong amount being put in. But for that number of bikes to be affected is very odd. Did they give you an explanation? Who did the installation? The guy at Rivi barn isn't being entirely accurate, it WILL seal a small to medium sized screw puncture if the screw is left in or unscrewed when removed, if it's pulled out like you would a nail, the screw's thread will shred the hole's sides, which then won't close up properly and form a seal (found that one out the hard way at the start of a long weekend in France before I took the franchise on). This is especially the case on older tyres where there's less rubber on them, and the rubber that's left being harder through use. Interesting to read all your experiences though, both good and bad, people do seem to have a extreme love/hate relationship with the stuff, there seems to be no middle ground
  3. Nooj posted a topic in The Bar
    Hello. I've done this in the wrong order, my initial post is already done and the intro comes second I joined to answer a question about Puncturesafe, but the Missus has an FZ6 Fazer (I've also had two FZS600 Fazers), so will keep looking in on here from time to time whenever something falls off it, as it's me that ends up doing most of the work on it. Mechanically it's still sound, but it's in a bit of a state cosmetically. She has put 83,000 miles on it since she bought it new in 2005 though, so it's allowed to look a bit tatty round the edges. She uses it as her commuter (she has an '06 Tuono for fun) and takes it from Newbury into central London and back every day so it gets plenty of use and abuse in all weathers. I work as a motorcycle valet so it's not as shabby as it could be for that mileage, but it's a constant battle keeping it looking presentable
  4. Nooj replied to Diver58's topic in Naked
    Hello, this thread came up in a Google search I did, so I thought I'd join up and answer for some questions and comments. I'm a Puncturesafe franchise holder (and do have a Fazer in the garage, so have a legitimate reason for joining as well) and am happy answer any questions you might have. I'm not here to push for sales BTW, just offering advice. Puncturesafe and Ultraseal are not the same company. Puncturesafe used to be the UK distributor for Ultraseal, but had a falling out over the recipe a few years ago. Puncturesafe have gone on independently to improve the original Ultraseal mix making it more stable and hard wearing, eliminating the problems Ultraseal were having. Needless to say it was not an amicable split. They've done a LOT of R&D and this is reflected in the quality of the product... and the price. But you do get what you pay for, cheaper sealants have a nasty habit of drying out and balling up in tyres, causing the well documented balance and vibration issues. It will prolong a tyre's life by dissipating heat evenly across the tyre's internal surfaces and transferring heat more effectively to the rim. Heat build up is a major safety issue if your tyre is under inflated for what ever reason, it's what causes delamination and blowouts. I know warm tyres are desirable on a bike, and they will still get warm, but normally the crown of a bike tyre will be quite a bit warmer than the sides making cornering on cold roads after a long straight a bit sphincter twitching sometimes, Puncturesafe will take some of the heat from the crown and transfer it to the sides of the tread giving a more even temperature over the whole treaded area. Re: Prefering to know if there's a problem with the tyre. You should be checking your tyres for damage regularly anyway, but as soon as a tyre is punctured the sealant is pushed into the hole sealing it. It prevents air getting out, but also prevents dirt and contaminants getting in, so there is no danger of ply separation or anything like that. Put simply, the tyre is no longer punctured, it's instantly fixed, so there ISN'T a problem with the tyre to be aware of, same as if you plug it yourself only without all the faff and time wasting that it involves. It's far far safer to ride on a fully inflated tyre with sealant and a nail in it, that to ride on a semi inflated tyre with aerosol trye weld in it. It's not a bodge, it's a permanent fix as strong and reliable as a DIY bung or professional repair. If you do see a nail in your tyre you can pull it out or leave it in, it's up to you, it'll still seal a hole up to 6mm... provided there's enough elasticity in the tyre's rubber to close up again and grip the particles in the sealant that form a clot. New tyres will seal better than old tyres because there's more rubber for the sealant to work with, so I actually prefer to leave a nail in an old tyre. Quite often if left, the head will wear away and the shaft of the nail will work it's way into the air cavity where it will rattle round harmlessly inside the tyre. The hole will still seal. If you find a screw in your tyre, don't pull it out, unscrew it instead. This will leave a much smaller hole to seal. Puncturesafe WILL NOT seal a 'dangerous' puncture, anything a tyre fitter wouldn't plug, any damage to the sidewall or any structural damage to the tyre will result in a 'Controlled Deflation', buying you enough time to stop and pull over safely while remaining in control of your bike. Anyone who's experienced even a mild puncture on a bike will know how quickly you can find yourself with no control over the bike what so ever. It's a proper brown trouser moment and not at all fun. Puncturesafe CAN seal tubed tyres, but as there is always an amount of movement from a tube inside a tyre, a nail in a tyre will sometimes 'saw' through a tube as it rubs against it, in which case you'll get a slow controlled deflation. It won't make a mess come tyre change time unless the fitter is a sloppy worker. It's thixotropic, so when your tyre is turning out on the road, the sealant becomes a liquid flowing freely around. When your bike is still, the sealant reverts to a gel and clings to every surface inside the tyre (it also seals porous aluminium/magnesium rims and inhibits corrosion in steel rims). If some does escape, it's water soluble and environmentally friendly, so is easy to mop up/hose away. As long as your wheels are balanced correctly, the bearings are in good condition and the correct amount has been installed, you won't know it's there until you need it. Yes, I do use it myself, between the Missus and myself it's in three bikes, a car and a van at the moment, after a few years of trying different sealants out this was the one that performed the best by a long way which is why I bought the franchise when it came up. We've done track days, drag racing, European tours and commuting with it in, racking up well over a hundred thousand miles between us and we've never had any problems with it. I'd never sell anything to anyone that I wasn't happy to use myself, I don't recommend it because I sell it, I sell it because I recommend it. If anyone has any more questions about Puncturesafe (I can't really comment on the other sealants in detail) then I'll be happy to answer them.
