9lence
Everything posted by 9lence
  1. I did not mean to use and abuse and yes I am sure you will as I am also the proud owner of a 2009 yamaha yfz450r I really do appreciate the help thanks
  2. Well I just rode it about 3 miles and it got better and better and better every time I rapped it out it was cleaner and that was my first time riding a street bike but it screams between 8500-10,000 now for sale before i hurt myself cheers to all and thanks again
  3. No 7 hours south from chicago I am at the very bottom of the state. But the bike just ran excellent it even idled better gonna let it run for a couple twenty minutes and see if it stays on all 4 cylinders Thanks a bunch guys
  4. Thanks guys. no it has not been cut there was alittle crust in there i cleaned it out and shot with wd40 havent started it yet waiting on some gas. I am about to start messing with it again today.. I am located in Southern Illinois US....
  5. cleaned carbs changed plugs drained old gas and put new started it it ran good for a minute or so then started dropping cylinders but 5 minutes later when I go to start it after i mess with the connection to the ignition box and the connectors for the coils it runs on all 4 again and will do the same thing. sometimes It will crank and crank and crank and just backfire and not start at all
  6. Thank you very much for you reply's I have to get some gas in the bike before I can tinker on it anymore. then will update with what I find.. Out of curiosity what is a 88 fz600 with 8000miles on it in mint condition worth if it ever runs I was thinking 1200-1500 am I off?
  7. I can try that Do you mean the swap the connectors that come from the top of the coils or just swap the plug wires around??it is not always the same 2 cylinders but for the most part it is cylinder 2 and 3 and sometimes hey all fire and it runs good must be something small I am just missing it.
  8. Excuse my ignorance but what is a "knackered" coil? Is there anyway I can fix this problem relatively cheap??
  9. indeed I did look there.. All I found was a lighter that doesnt work and a empty pack of smokes... and the bike still doesnt run good lol .... but on a serious note any suggestions as to what could be going on with thing?
  10. I bought this bike awhile back and have never gotten it to run right sometimes it will fire right up and hit on all 4 and some time it runs on 2 cylenders sometimes it wont run at all I did some reading on here and unplugged cleaned and plugged back in the connections from the coil it seemed to help for about a minute then it went back to its old ways. I also unplugged the connections for the Ignition box under the tank and when I plugged it back in it was better to but always goes back to running like crap any suggestions or advise would be greatly appreciated thanks
