scanty
  1. fine. i had messed up with the adjustments. got it starting now, just not running right. at least i can now get it to someone who really knows what they're doing.
  2. may have been a bit hasty. now won't start again and me battery's dying. got the problem narrowed down, just need the juice to start it. few phonecalls gonna have to be made
  3. sorted, it was that. was trying to fire but just wouldn't catch. cheers anyway
  4. could it be this? adjusted the other day and was running fine. 2 days later and nothing, turning over but won't fire
  5. what colour's your bike? there's a silver l/h panel on the bay for £20, although delivery's another tenner
  6. had the same thing with mine. if you've still got the plug, try araldite. should be strong enough
  7. i just recently had a problem with mine starting. probably not the same problem you're having if the engine management light's not flashing. would just recommend trying the cheap stuff first. my problem was a faulty ignition switch by the way. which i discovered after removing the tank and half the electrics. you learn by your mistakes i guess
